Something like this. Wood from the same tree. Tung oil, rubbed, by my wife.
Looking closely at this base it looks great. Here are some ideas on finishing it. 3 Tricks for a Beautiful Walnut Wood Finish – Woodworkers Source Blog
3 coats and 600 grit. Still trying to decide if I'm going apply a paste wax. There's just one problem. I made it symmetrical and the top plate is a rectangle. Either I make a 4th base or order a new top plate.
Distance between pcb and top plate is 1/2". Standard heat sinks, mounted on the bottom of the board along with the cap's. The big resistors should go on the underside also.
Haven't got a clue how to share the file. help would be appreciated. You might get ahold of front panel express and ask them about the design. Tell the I sent you.
- More Vendors...
- Tubelab
- TSE & 45's
