Alex from Oz said:No worries.
Although, I could still make up some sheets for your newly built BIBs to experiment with in the days after the event.
Let me know.
Alex
Those that decide they like their BIB's sound will - I dare say - build them again with glue, terminal block, etc. Those people may be interested so I'll mention it.
Doug
Brisso57 said:
GM, what's the appropriate Zdriver for this modified spec?
30", same as TC's since I used his pipe length: http://fullrangedriver.com/singledriver/DIYTQ8.html
BTW, if the driver will fit on the side and if wall space plus WAF allows it, a bit more bottom end reinforcement can be had with the wider baffle/greater mouth area loading.
GM
Brisso57 said:Thanks but I think we'll be pressed to just get the basic BIB's built, including stuffing. It's a one-day project. The second half of the day will be spent listening and im-BIB-ing (ho ho ho!)
For kicks, I dare you to do one out of EPS foam and tape - it works far better than it should - how fast can you knock one together?
Date set for the Int'l Build-a-BIB Day!
30 May has been agreed by the SE Qld (Oz) participants.
I'll have my camera there and no doubt the pics will appear on Greenie's site.
Doug
BTW ... when using a small driver (and hence having a shorter BIB cabinet) would it change the sonics noticably if the cabinet were built with taller sides, and the floor set higher, internally? The purpose being to raise the driver height to a better listening position?
loninappleton said:Glad the BIB thread is going again.
If the Build a BIB is making knockdown builds, then maybe at some point the Enabl sheets could be added after. Looking forward to lots of pics for this.
Doug
Re: Date set for the Int'l Build-a-BIB Day!
That's what I did with the FE127e: you optimize the height of the driver and GM would say even put it higher to give a good concert effect. Besides, the longer you leave the panels they have potential for reuse on other builds.
Doug
Other thing:
Godzilla shows a good method of widening the front baffle rather than use of a supra-baffle: his front is made wider than the width dimension for the BIB internals.
http://www.zillaspeak.com/bib-godzillabib.asp
If I redid the BIB, I'd incorporate something like that because I like to use grilles.
"Offset" a good idea?
Yes. I'd noted that. Frankly, suprabaffles can look a bit weird sometimes. I'd go for the extra-wide front baffle. I've also noted suprabaffles are sometimes used to pack out the driver if rear clearance is tight. In that case, I'd be inserting a whole extra thickness of some cheap material, chipboard maybe.
cheers
Doug
PS If I do make the front baffle wider, is there any benefit in (i) keeping it symmetrical? or (ii) deliberately adding more to one side, to create an "external" offset? (The driver remaining symmetrically set as far as the internals go.)
loninappleton said:Other thing:
cheers
Doug
Re: "Offset" a good idea?
Well, if you really want to get into this.... A while back some peeps showed a spiral conch shape baffle with a defined ratio for expansion to the edge of the baffle. If you made a left hand and right hand baffle to this ratio and if you stood them together they'd look like a heart as in ..
I heart BIBs.
Maybe someone remembers this and can give the link.
A number of experiments have shown asymetrical wings with the bib design.
cheers
Doug
I heart BIBs.
Re: Re: Date set for the Int'l Build-a-BIB Day!
Right, though fill the cavity so it won't 'drum', preferably with something fairly dense such as kitty litter, sterile sand or similar.
GM
GM
Ideally, the driver would be offset internally also if the baffle is wide enough, then the external 'wings' would have to overhang both sides to maintain the offset, though the ratios could be different, so there might be an acoustic ratio that only requires a 'wing' on one side.
GM
Brisso57 said:
.........or (ii) deliberately adding more to one side, to create an "external" offset? (The driver remaining symmetrically set as far as the internals go.)
GM
coral 4A-70 project
hi,
reading more, digesting.... with the response from the little 4a-70's being limited below 500hz and a bib filtering backwave energy above 300hz, am i barking up the wrong tree with a bib.
would it be more sensible to jump threads and continue on the open baffle discussion -
saw peter strassackers translucent exponential baffles on lautsprechershop.de....
still waiting for t/s values on corals, will follow that up today,
thanks all, a
hi,
thanks all, a
Internal Offset of Driver
GM, could you expound a little more. After playing with the computer program called The Edge, and experimenting with temporary baffles that are offset, I have concluded that good things happen. The program, and my ears tell me that the FR gets smoothed out, and the missing mid and upper bass get filled in, with my ongoing speaker project.
What will happen if I also move my driver slightly to the left or the right in relation to the vertical center of the cab? I am right at a place where I could do it for my final stage of the longest BIB build in history. I am inclined to position my driver up to a half inch (that is all the room I would have) in the same direction as my "wing".
As far as the wings go, when I played with The Edge, it seemed logical to me to add a second wing on the opposite side, but even a tiny amount would make the FR bumpy again.
Sincerely,
Benjamin
Sincerely,
Benjamin
Re: coral 4A-70 project
Greets!
Obviously, small drivers can only sound truly 'big' if compression loaded with a large horn to increase its radiating area, which severely BW limits them, but pipe horns (especially if corner loaded) can provide enough acoustic gain to ~tonally balance a small/low Xmax driver to well below its Fs and where it begins filtering backwave energy is a function of its effective Qts and surrounding boundary loading (baffle, etc.), so we won't know anything definite until the specs are in.
If you want to get the best out of a 'FR' driver though, then OB with both a woofer and super tweeter system is required, which of course drastically increases design complexity with its own set of performance trade-offs.
Your call..........
GM
Greets!
Your call..........
GM
Re: Internal Offset of Driver
'Expound' in what way? I haven't used the 'Edge', much less compared it with real world measurements, but considering who designed it I imagine it's theoretically correct, which is about all one can reasonably expect from a sim, so it can be used to to see how moving the driver across the BIB baffle affects it internally or externally, though I assume it won't do both at the same time, ergo a certain amount of interpretation on your part is required to 'see' the summed effect.
That said, unless a cab is wide enough for its wall's eigenmodes to be down in its BW, then offsetting a driver is a waste of time since the internal wall damping will quell them, so concentrating on getting the external baffle size/shape and driver offset right is all that matters.
GM
BenjaminWebber said:GM, could you expound a little more.
GM
coral 4A-70 project
to the woodshop!
picked up my corals from axent - still no t/s figures.... making a tiny enclosure to test 'em is , it seems, in the too hard basket for them....
however, i cornered kelly the bossman there - he's sure they have the specs for the corals from '83 when they used them last....
confirmed that the 4a70 will work in a back loaded horn, a super slim tl or bottom ported mltl.... can rummage up appropriate filter components to blend to a woofer if needed......
suggested tuning to about 90hz and working down, so it seems best thing for me to do is the classic bib form for mk 1 and just see how it sounds.
thanks gm, confirmed my very rough understanding of tiny-driver/bib principle....
will see if i can get panels cut this weekend,
a
to the woodshop!
a
coral 4A-70 project
hello again,
checked in with friendly woodworker, going ahead with mk 1 dimensions, maybe ready by sunday ( hope someone touching wood )
for mk 2 - any advantage to 'stretching' the recommended line to a full ten feet, (5ft folded...) keeping volume equivalent... making taper longer ratio, narrower baffle, longer delay to backwave?
(room actually tall enough to take 10 ft unfolded - a couple of feet to spare, art nouveau apt, originally had gas light fittings; front room roughly 12w x 19l x 14h, going by my 6ft reach and a bit of squinting...)
thanks, a
hello again,
thanks, a
Greets!
Increasing its path-length lowers Fp and its 3rd harmonic dip, so it may, may not be beneficial and the lower it's tuned below Fs the more critical the need for room loading to protect the driver from over excursing, so based on your room's dims, I'm thinking there might not be enough corner loading to do it, but only one way to know for sure...........
GM
GM
- Full Range
- Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?
