Thanks a lot.Replace R7,8,9,10 with 1k instead 2k2, voltage on zeners must be about 15V
I have questions Mr......you prefer this amplifier with or without servo?
I have 3 pairs mjw21195/21196 .
Do you think that are proper for output?
Thanks a lot.
MJW21195/21196 will be ok, I use it in SR800 without DC servo for PA, but for hi-fi I suggest to keep DC servo.
sr200 studio refer.
Thanks Mr.
SR800?
Thanks Mr.
SR800?
My SR200 is now having a trouble, it has 250mV dc out...Q1-2, Q5-6 are matched pairs..I put 10pf between bQ2 to cQ9,
and values for R11 8k2, R18 2k2...
I need advice to solve my problem.
Thank you so much...
Best Regards...
Best Regards...
st
which value of R11 ?
Oh sorry i see 8k2
NOOOO R11=15K
Best Regards...
Oh sorry i see 8k2
NOOOO R11=15K
sr200 studio refer.
Arif Budiyanto read #1337 carefullyEverything starts from here.
This modification is the cause of the problem.
Today early in the morning about 5.30 o'clock i examined the amplifier again.
But this time I was sure for the pcb because it passed the point to point test.
As changing transistors and matchig didn't solve the problem, having in mind that the others' amplifiers didn't have the problem,i decided to return to the original circuit.
So i put at R11 the original value 15K.and that was all!
Thanks everyone for trying to help .
Especialy thanks Mr AdrewT who advised me to stabilize the LTP without servo.
Thanks a lot to John Balli for your instant reply in mine request for measurments.
Last but not least thanks overall feedback for his atempt to help.
Thanks again Mr.Mile for this excellent amplifier.
I also attach this hopping that it will be useful
Thank you dear Thimios for your suggestions.....Arif Budiyanto read #1337 carefully
I put back 15k for r11, 1k for r18, using 2X10pf caps in parallel for compensation. DC offset now is 133mV..
But when I disconnect dc servo, offset raise into 2,56V!...and when I put back dc servo offset is back to 130mV...
I am sorry that my background is an accountant just doing my hobby..so I am sort kind a lack of electricity background...
Thank you...
studio referance
Have a taste from Apex sr200 here.Apex sr 200 studio referance in action. - YouTube
Hi Thim, amazing mid isn't?
I see you're making a new SR200, which version is it?
BR,
Junie
Hi Junie how about your vacations?Hi Thim, amazing mid isn't?
BR,
Junie
This version is 3.2? .
Pcb by Alex mm of cource
3 pairs output.
MJW21195/96
Busy as usual.
I see, The final layout by Alex MM. Good luck with the build Thim.
Enjoy your vacations .
Thanks Junie.
studio reference
I see that your problem is still there.
Did you have any measurements about ltp transistors?
Q1 Q2 VR11 VR12 VR13 VR16 VR17
Measurments are on the shematic, see post #1337.
Is this a previus running amplifier or a new board?
Hi Arif .Original schematic with 20pf cap...something wrong with my SR200 amp..still struggle with it...
Maybe I will disconnect zobel network from pcb and put it in speaker terminal...
I will up load another photos.
Add 20pF only if amp is unstable, no need to add compensation on stable amp.
studio reference
Tell us a simple test in order to check the stability of an amplifier.
Is the parallel capacitor to dummy load the appropriate method ,until what capacity the amplifier must be stable at full volume gain.
Regards.
Hi Mr.Add 20pF only if amp is unstable, no need to add compensation on stable amp.
Regards.
Hi Arif .
Ok Thim, thank you so much for your very kind attention. I will do measurement when I am fully recovered from my sickness soon. This is my 4th SR200, I have been Ok with 3 previous Sr200 amps. My friends really love these amps. And I want to build SR200 for myself. No commercial use only for hobby. I am just proud when some one likes my amp...
Dear Mr. Mile S...
thank you so much for your kind advise as always...
I will check my amp again...before it is fine only zobel network was hot when playing couple songs...
Strange behavior is, when first turn on, the dc offset is high, 300mv and more, and getting down after more or less 10 minutes up to 14 mV...
the sound is Ok...really like this amp...
- Studio Reference Amplifier
