SEWA - Seven Watt Amplifier
Re: output impedance question
Tyimo said:
Hi Mads!
Could you tell me what is the correct output impedance of the SEWA and the OTA amps??
Greets: Tyimo
Hey.
If you go back to beginning of this SEWA thread (maybe first or second page)
The Output Impedance was discussed in several posts.
And they got to some figure.
It might also have been in OTA-thread.
If you can not find those posts, Mad_K will tell you the output impedance.
Hi Lineup!
Sorry, but there is only about input imp of SEWA and output imp of the preamps..... if I looked well.
My question is: what is the output imp of the SEWA power amp.:)
I know I should measure it, but it would be very uncomfortable for me. (Signal generator is far from the amp.....) May be your simulator program could tell us?
Greets:
Tyimo
Re: output impedance question SEWA OTA
lineup said:
Hey.
I might have an old brain.
But there is Not often anything wrong with Lineup Remembering
... in 20 years from now, when I am 75 years old, we will see.
... but now, no big problems - Lineup Memory better than many young :D
OTA - One Transistor Amplifier
See Posts #56 - 88.
They tell How to calculate approximate Output Impedance of OTA.
Now, you know that OTA and SEWA are brothers.
They are same circuit!
Which means ................ what ...... ?
lineup
Thanks Lineup!!!
I found it! You have realy good memory.:D
Thanks for Babowana too!
Output impedance (without the speaker load) is the paralleled
resistance between 1/gm(transconductance of the fet) and the total resistance below the source.
So, am I right: OTA output imp will be with 10R source load and IRFP150 Gfs14 ca. 70milliohm??
How can I calculate with common source amps?
Greets:
Tyimo
Tyimo said:
Thanks Mads and Lineup!
If I would measure it should I like this:
Output impedance=(Load resistance*(Vunloaded minus Vloaded))/Vloaded
Tyimo
That is the best way, practical measuring, two times, with different loads. The output voltage will sink with a value that is proportional to the loading.
Maybe theoretical calculations can come close to same value.
But we also know that no 2 devices are alike.
Which also means,
that no 2 amplifiers even from same schematic are the precisely the same.
Even 1 % resistors can be +/-1% different ( 2% span ).
And are many resistors in an amplifier.
lineup
I meant guess or measure the transconductance Gfs (gm) IRFP250N has 17S @50V/18A. Let's guess it has 3S at 15V/3A. Output Z would be 1/3S // CCS (very large number) // 1K (bleeder) // 8ohm (load) = somewhere around 0,3ohm.
To measure the output impedance:
Apply a 1KHz sinus for 10V output into your scope. Attach a load (10R for example). If you are measuring 9,5V across the load, your output impedance is what makes this voltage drop ;)
Edit: your formula is correct Tyimo :)
Hi Mads!
I found only one usefull info about the transconductance characterics. It is the IRFP250 from Fairchild.
Am I see right that it has on 2-3 amper 5-8 S??
Greets:
Tyimo
Tyimo said:
Hi Mads!
Greets: Tyimo
resistance
Tyimo
one thing I have wondered is
Why do you want to know output impedance of your SEWA?
Like Nelson Pass, sometimes 'The One and Low DampingFactor Man',
I don't worry about output impedance,
as long as my amplifier will have a good performance - at work :)
We have discussed damping factor in a long topic some years ago.
My opinion told in beginning of thread,
was later in thread backed up
by Nelson Pass telling his experiences on damping factors, in his amps.
Originally posted
by lineup
11th July 2002 11:58
nothing to pay any greater notice
Damping factor is something I never
understood either.
A welldesigned amplifier doesn't have to worry
about damp factor.
Regards, lineup
