I am working non-stop to ensure that the entire GB, will be shipped before Christmas, but I can not guarantee that everyone will receive before Christmas.
I left for the latest version 120Vac because expected the main filter capacitors (already arrived) 680uF200V +270 uF200V.
Today started Packages:
PandazYa
Robyer (120Vac 6xDPS-400)
Tomorrow others.
PandazYa
Tomorrow others.
Tomorrow others.
Life is strange..i'm.., i suppose, the nearest to Audiopower\MDI..For sure i was the first subscriber in SDA GB..But...not shipped..not received..and i'm not in 120Vac.....maybe lost in the sea of Stretto di Messina??
Very ironic..i'm not able to listen to my "transoceanic" mda due to the missed connector and pins..
As usual.....and, as usual i apologize for my poor English
Ciao
Maybe I have "strange" via to set Priority in my mind.Life is strange..i'm.., i suppose, the nearest to Audiopower\MDI..For sure i was the first subscriber in SDA GB..But...not shipped..not received..and i'm not in 120Vac.....maybe lost in the sea of Stretto di Messina??
Ciao
I know well that Pinnocchio have send me the payments before others... but exist a good reason if I close and sended packages at others, reason functional only.
I missed usual the connectors and pins??????
I can deliver all rest of package in side 22 Dicember. some that can not wait, please ask refund. I'm sorry but not are able a better solution. I'm stressed-tired-Stressed out of measure a lot...
PandazYa
Tomorrow others.
Hi AP2,
Thank you for the update. Does that mean that my 6 SMPS have shipped? If so, can you please provide the tracking number when you have them?
Thank you very much.
Bertrand
Hello Danilo, this is the connection diagram for your DPS-400.Ok, DPS400 for IcePower ASP500 arrived, now I have to just connect all them together...
Next look for a suitable case.
I think it is simple, however, are well available if you want, even to the arrangement of the modules.
You should have no problems with noise even if you assemble it on a wooden base for the test.
- Vendor's Bazaar
- SDA-400 Professional multi-way
