it really doesnt looks like it is leaking... i see nothing at all that would look like leaking and the caps all looks mint ... the spots i am talking about are underneath the PCB on the solder side... like when an electric spark occurs.. them look like the ones i make when discharging the caps with my headlight.. but way more dark
Even if the MIC4420CT was blown I have never seen one cause these problems such as you are having, not saying it isnt possible but unlikely. It almost sounds like you have a shorted output(s). Run the test like Perry said alot of times by checking the resistance form gate to source you can tell if a fet is shorted. Especially if you have 1 with a really low number like 1.9, 2.4, etc etc.....
Maybe the rail caps being out are affecting your readings, if their fine you should re-install them and recheck the gate to source resistance on the output fets. I am sure Perry will chime in to steer you in the right direction soon, he is probably reading your zillion posts.....LOL
- General Interest
- Car Audio
- rockford fosgate BD1500 stopped working
