The subsonic switch has 6 pins. I tested the midlle two. One pin has no signal either position. The outer middle pin towards the edge of the board has a good signal in one orientation and the same funny looking signal in the other position. The signal clips up top then the bottom wave form jumps on top and gives a square signal in between the wavey signal of the top wave form.
What if you reduce the signal so that the sine wave isn't clipped? Do you then have a symmetrical sine wave?
