Hammond 229B56
Cx 10nF
Cs 150nF
Rs 480Ω
What's the recommended wattage rating of the 480ohm resistor? Does it need to be 2-3w, or will .5w work?
Rejdr,
Try this. I think Mark Johnson put this up a while ago.
Short version - 0.5W is probably fine.
I used 1WWhat's the recommended wattage rating of the 480ohm resistor? Does it need to be 2-3w, or will .5w work?
Here are the results for the hammond 229C40.Quasimodo results (ONLY)
Can I for the same VA type xfmr (229C), lineair interpolate the Quasimodo Rs value for other output voltages?
E.g.
- 229C40 ==> Rs= 577R
- 229C24 ==> Rs= 577* 24/40
E.g.
- Power Supplies
- Quasimodo results (ONLY)
