That Amplifier, can handling hexfets for output devices?
Something like 4+4 IRF540 at +/-70vDC
No
hi all
can i use c5198 instead of 2n3773 at above pcb ? is there any change need?
i need about 50w power .
thanks.
You can use 2SC5198 with +/-35V without any change.
I also agree with bepowell and JC. There are several basic errors that beginners would not be advised to make:
(1) no emitter degen = slew induced distortion
(2) no emitter ballasting resistors in the lower NPN output transistors =recipe for disaster (current hogging in one transistor)
(3) 2N3773 was never a good transistor (ft=200kHz when RCA made it. Devices today won't be built the same but fT spec. has not changed.
I also agree with bepowell and JC. There are several basic errors that beginners would not be advised to make:.
I made an error with my first quasi.
I put the electrolytic feedback capacitor in wrong way around.
Due to different driver stages for upper and lower output transistors the feedback DC voltage is negative so cap has to be in the right way around for that.
A severe reactance speaker can demand peak currents of around 3times what the equivalent resistor would draw on fast changing signals.
That peak current has to come through your output devices.
The driver must be capable of driving the gate/base of those outputs.
I allow for 15Apk in a 100W into 8ohms speaker instead of the usual 5Apk into an 8r0 dummy load.
The output BJT will have a lowish hFE at 15Apk output, so the drivers may have to pass around 1Apk for a millisecond or so.
Supplies of ±80V into 4ohms is in a different field.
Are you really aiming for 500W into 4ohms and yet don't know how to assess current requirements?
BTW,
500W into 4r0 dummy load is already up above 15Apk and that is without applying a fast signal into a reactive speaker load.
BTW,
BTW,
MAX current via driver transistor is 0.66 * 3 times about 2 A .
Now we look for driver 150-200 V , 3-4-5 A .....
I'm worried because the last amplifier which I did with Supply + -80 volts driver was the same as the final transistors ....
yes, I do a lot of amplifiers from 500 to 1000 watts but ready calculated schemes by someone else. Now I want to learn to do calculations alone.
which is the minimum supply voltage that this amplifier can work?
below + -35 volt sine wave is heavily skewed , by multisim 11 ....
thanks admin..... sir i need pcb layout for this bgw and parts placement... i am looking for this for many years... thanks in advance...have this amp as quasi and complementary model 750 B
HELLO ALL
I CAN USE 2SC3858 ?
WHAT ABOUT -+DCV IF IC CAN USE 6 TRANSISTOR 2SC3858??
MY PCB
I CAN USE 2SC3858 ?
MY PCB
http://www.up-00.com/I CAN USE 2SC3858 ?
WHAT ABOUT -+DCV IF I CAN USE 6 TRANSISTOR 2SC3858??
i try make stereo amplifier ???
Yes you can with +/-60V DC
- QUASI Amplifier for Beginners
