Pumpkin Shunty begins....
Say, I know you are using same BOM, it appears it lists R10, 10a, 11,11a as 6.81k, while cookbook shows (correct of course) it as 33k. 6.8k should be R9, 9a, 26, 26a. Looks like they skipped the 33k..Also don't show R9, 9a, 26, 26a at all.
Russellc
Thanks for the heads up... I've got those correct - I basically used that BOM for part number ideas, then went through the cookbook list, and I double checked the cookbook list (and the conversations here) before the order. In hindsight, I ended up choosing different parts for much of what is on that BOM, but it was a big help in getting started.
Tod
Joined 2003
Tod
Precisely how I caught it. Good eye. I still have a bunch of odds and ends to order so no big deal.
Russellc
Pumpkin bypass caps question...
ZenMod,
While I wait for the Shunty parts to arrive, I'm looking into other parts, and, for the Pumpkin, I was wondering about the bypass caps (C11,C12) for the output coupling caps (C4,C5) - one point of view is that you should just get a nice coupling cap and forgo any bypass cap, for example: "Bypass capacitors create multiple signal paths with multiple time constants. These time constants are very short but they can still be heard as a smear or overall loss of focus." <--(I've read basically this in a few forums.)
Any advice/experience on how to pick C4,C5 for this design? I could see splurging (a bit, nothing with beeswax and gold :)) for a nicer film cap there, and maybe losing C11,C12 as one approach. Or standard box film and nicer bypass. Or just boxes all around (prob Wima) and forget it.
Tod
Official Court Jester
Joined 2003
my fave bypass cap is MKC , polycarbonat , as big as I can squeeze in physically
and yes - I can hear bypass , when done properly , with positive results
I'm just amused with anal approach from yore - several bypass caps , each having 10% size of preceding one
btw. cheap and hard to beat solution is Elna Silmic 10uF + 1uF MKC
proven exactly in M2 , and several gadgets before and after
Joined 2003
Joined 2003
all of these are good
practically - put there anything you fancy ( or already have in drawer) in size from 470uF to 2200uF
important is decent quality , so decent name on them
even with trice 470uF filtration is sufficient and - what's most important - you'll not hear difference if you put trice 2200uF
who sez I'm not flexible :clown:
Joined 2003
I think 63 volt sufficient for the Antek transformers I am using, is there anything to the 10000 vs 5000 hour life, or ripple differences? plus I assume that 100v would not be as stressed as 63 volt giving longer life or am I off base here as usual?
Russellc
my big shunty parts order arrived
Always like a mini-christmas when a box full o' parts arrives! And the backordered heatsinks from Allied just shipped. So, maybe I can actually build the shunties this weekend - that would be nice, I'm pretty tired of the parts ordering and would like some results!
Tod
Joined 2003
Allied came through and the two smaller sinks have arrived, so all sinks are now in hand
While the larger sinks have enough meat on them for drilling and tapping, the little ones are very thin.
To those who drilled and tapped these smaller sinks, what size hole did you tap? It must be tiny?
Russellc
Joined 2003
Zenmod, while waiting on last of Shunty parts I am looking at the Pumpkin boards. Comparing required resistors to on hand, I noticed R7 on Pumpkin board has 3 solder pads. An extra one in middle.
Looking at schematic, at first I thought it was R14, but on board has its own 2 pads.
Brief Reading of cookbook didn't reveal anything.
I am sure it will become obvious at some point, but I have to ask, what is this pad for?
Russellc
