Post your Solid State pics here
Here is my A/B speaker switch completed and installed in its case. This is one channel - there is another identical box.
"The Saint" 's design
tmyr!
..this is my realization of a PtP n-hexfet stereo amp ("The Saint" 's design.. thanks man.!) with 1 pair of industrial 60Amp peak current fets & ecc83 triode buffer per channel, @ +/-33v rails, fused protection, soft start delay, descrete geared attenuator pots, a balance pot (hi-fi style) & 6 input selector+rec out, hand made to the bone.
Where can I find info about this amplifier? Schematic, etc.
Greets:
Tyimo
Hi Bonsai
Thanks for your kind words. A couple of years of work has gone into this design.
Regarding the SMD, I have my own computer controlled reflow oven.
So all I have to do is stick the components onto the solder paste and it takes about 3-4 mins to go through the temp controlled profile and hey presto a perfectly soldered SMD board.
The remaining hole through components are done by hand of course.
I will be getting these professional made in the USA.
I have made some good contacts there.
Mighty, mighty powerful looking = >> 1K watts?
Can you find gold plated stab on connectors for that? ...
I ran into a mounting question for those MOSFETs ... the holes are japanese diameters (metric), so all the pretty #6 brass screws I have won't quite fit. ... Not really a problem if you have a source for 1.5 mm brass screws (is that the right dia.?) ... But, here in the states, that's a peculiar happenstance = not available @ Ace Hardware ... :eek:
By the saint - Well done on the construction
And very nice amps.. :cool:
I have a question .. I have 2 HUGE amps coming (160lbs) and
if for some reason unforseen , I can not restore one of them
I have recommended your modules (Nxv 300 /500) as a
worst case replacement.(he prefers the original class A)
These amps...
http://img.photobucket.com/albums/v517/esop/Picture080.jpg
Have 2 -1.5KVA+ trafo's with 100k+ capacitance at +- 72V.
If I can't repair the first one , the owner stated that he would like
to make a super powerful dual monoblock out of it.
If I am successful with #1 , he actually has a third unit that
he would like to do the same modification to.
the thread is here..
http://www.diyaudio.com/forums/showthread.php?s=&threadid=46602&perpage=25&pagenumber=2
I am just on a fact finding mission to see if pricing/ compatability
is reasonable for a PS of this size and is the topology
in these NX's similar to your earlier designs (av400, etc).
I did recommend your amps, so if you respond it might make
the customer more receptive , even if this modification
is only done on his 3'rd amp.
PS . I will have one of these as well..
OS
