Philips CD650 mods
Hi Simon,
for feedback, the one I had in hands ( an Alpha Plus ) has seen a new TL1086 fitted at SAA7220 and recaped/osconed board, OPA604 at I/V andLME49710 at buffer. 2x 3.3µF 750V Wima MKP4 at output.
When I've asked the owner if it was "better" he said, "no, it's far more greater" ;)
Seems these opamps work nicely, anyway you'll go for the D1 :)
Pics of your work please !
Matthieu
I've got a set of PPS for this job from Farnell. Not fitted yet tho!
I'm using varying values as per the info on the TDA in EC's NOS thread.
MSB
1uF 9694315
0.22uF 9694277
150nF 1657955
33nF 3835303
33nF 3835303
8.2nF 9694889
8.2nF 9694889
LSB
I think the changing value is all to do with the timing and bounce of the bit landing on the pins. It should help to align the timing and be more accurate. See the link in post 963 for details
Ian
Superreg improvements
I'm starting on the mods for my Mission 7000 which is very similar internally to my 160.
I'm very happy with the sound from the 160 where I have seperate LM317 based Rayregs for opamps +-15, DAC +-5,-15, Saa7210 +5 and clock +5.
I have a flea ready for the clock supply in the mission and I'm toying with using bought-in superregs for the other 6 supplies. That's going to cost somewhere between £200 - 240 (depending on whose regs I use). That's quite a lot of money so I'd expect a pretty good step improvement. Anyone else made this step and can advise on results / value for money?
Pete
