PCM56K iv resistor value?
And make sure that you solder the opamps to the adapters correctly and insert the adapters in the pcb correctly. Pay attention to the pin1 markings on the adaptor.
Also ic607 and ic608 adaptors need only one opamp each. See schematic, one output goes nowhere. ic11 is for headphones.
re- pcm56
ok, very thanks,
the last question :
you raccomended the improvement across the dac board would have power to dc battery ?
..................opa627 AM.AP,APG4,AU, BM ????? which ?
dear, i would buy the Opa627 but which ???: Confuso:
OPA627AM NRND TO-99 LMC 8 20 Green (RoHS &
no Sb/Br)
AU N / A for Pkg Type
OPA627AP ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627APG4 ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627AU ACTIVE SOIC D 8 75 Green (RoHS &
no Sb/Br)
CU NIPDAU Level-3-260C-168 HR
OPA627AU/2K5 ACTIVE SOIC D 8 2500 Green (RoHS &
no Sb/Br)
OPA627AU/2K5E4 ACTIVE SOIC D 8 2500 Green (RoHS &
no Sb/Br)
OPA627AUE4 ACTIVE SOIC D 8 75 Green (RoHS &
no Sb/Br)
OPA627AUG4 ACTIVE SOIC D 8 75 Green (RoHS &
no Sb/Br)
OPA627BM NRND TO-99 LMC 8 1 Green (RoHS &
no Sb/Br)
OPA627BP ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627BPG4 ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627SM NRND TO-99 LMC 8 20 Green (RoHS &
no Sb/Br)
For you: Arrow Central Europe, Arrow Northern Europe, Digi-Key, Mouser Electronics...
re- pcm56
Dear,
'I do not understand, fording the data sheet of opa pins are not equal
NJM5532s :
output : pin 1
output ; pin 7
OPA 627 : output pin 6
perhaps with the adapter all is' right?
us before you make a fault in the cd
please see the data sheet and help to my.
thanks luigi
Those are different packages. The adaptor from previous pages requires SOIC (letter "U" in name).
The "2k5" in the name means it comes on reel of 2500 - irrelevant for you, since you don't use automated process. The "E4" and "G4" are irrelevant for you also.
