re- pcm56
I can replace NJM5532S
with opa627 with adaptor without modified circuit of my cd player ?
please look the file schemeats add
The usual suspects, opa627 on dual adapters ?
re- pcm56
8 in a line.
8 in a line.
Do the opamps have 2x4 pins or 8 in a line ?
SIL single-to-dual Op-Amp Adapter (p/n 040701)
re- pcm56
Very thanks for your help,
please the last questions :
Once installed opa 627 with the adapter does not have to do more 'anything?
resistance, capacitors must not be changed? ok?
where can I buy opa627 ?
thanks luigi
thanks luigi
And make sure that you solder the opamps to the adapters correctly and insert the adapters in the pcb correctly. Pay attention to the pin1 markings on the adaptor.
Also ic607 and ic608 adaptors need only one opamp each. See schematic, one output goes nowhere. ic11 is for headphones.
re- pcm56
ok, very thanks,
the last question :
you raccomended the improvement across the dac board would have power to dc battery ?
..................opa627 AM.AP,APG4,AU, BM ????? which ?
ok, very thanks,
the last question :
re- pcm56
but my dac's main bord work 5 volt -12 volt
I am in error ?
please
see the schemeats
thanks luigi
I am in error ?
please
see the schemeats
thanks luigi
I have never tried battery power supply.
You would need many batteries...
dear, i would buy the Opa627 but which ???: Confuso:
OPA627AM NRND TO-99 LMC 8 20 Green (RoHS &
no Sb/Br)
AU N / A for Pkg Type
OPA627AP ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627APG4 ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627AU ACTIVE SOIC D 8 75 Green (RoHS &
no Sb/Br)
CU NIPDAU Level-3-260C-168 HR
OPA627AU/2K5 ACTIVE SOIC D 8 2500 Green (RoHS &
no Sb/Br)
OPA627AU/2K5E4 ACTIVE SOIC D 8 2500 Green (RoHS &
no Sb/Br)
OPA627AUE4 ACTIVE SOIC D 8 75 Green (RoHS &
no Sb/Br)
OPA627AUG4 ACTIVE SOIC D 8 75 Green (RoHS &
no Sb/Br)
OPA627BM NRND TO-99 LMC 8 1 Green (RoHS &
no Sb/Br)
OPA627BP ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627BPG4 ACTIVE PDIP P 8 50 TBD Call TI Call TI
OPA627SM NRND TO-99 LMC 8 20 Green (RoHS &
no Sb/Br)
no Sb/Br)
no Sb/Br)
no Sb/Br)
no Sb/Br)
no Sb/Br)
no Sb/Br)
no Sb/Br)
no Sb/Br)
For you: Arrow Central Europe, Arrow Northern Europe, Digi-Key, Mouser Electronics...
ok, thanks .
how many njm5532s to change?
four?
four?
Those are different packages. The adaptor from previous pages requires SOIC (letter "U" in name).
The "2k5" in the name means it comes on reel of 2500 - irrelevant for you, since you don't use automated process. The "E4" and "G4" are irrelevant for you also.
re- pcm56
but .....the pin configuration of two opa njm5532s and opa627 not are egual ?
with adapter it are egual ?
NJM5532s :
output pin and pin 7
opa 627 : output pin 6 : Confuso:
ok, thanks .
four?
NJM5532s :
re- pcm56
Dear,
'I do not understand, fording the data sheet of opa pins are not equal
NJM5532s :
output : pin 1
output ; pin 7
OPA 627 : output pin 6
perhaps with the adapter all is' right?
us before you make a fault in the cd
please see the data sheet and help to my.
thanks luigi
Dear,
NJM5532s :
output : pin 1
output ; pin 7
thanks luigi
re- pcm56
...I understand ..the adapter converts the wires to the
correct position. : Rolleyes:
very thanks luigi
very thanks luigi
Look close to the adaptor that I pointed on the other page and you will see...
- Digital Line Level
- PCM56K iv resistor value?
