I guess it al depends on how much "overkill" one is willing to finance in DIY... Most commercial class AB amps have their PSU's dimensioned far smaller than nominal RMS output power because constant full power output is rare. 50V rails minus say 5V drop should give continuous 125W into 8 Ohms if the heatsinks etc. hold... This times two means that nominally a 300 VA PSU is certainly OK for 2 channels. I will use 250 VA for 36V rails.
I have some questions too, about the BOM mostly: discrepancies with the original that are not related to thermal stability for instance etc. Maybe we should either, move the discussion of these matters to the original thread, or create a "AAK Symasym builder's thread" as customary...
No new date has been set,but we can do an interest check,If you are interested,tell me how many boards you want and I´ll start a new list.Has a new date been set for more PCB's to be made? Has there been enough interest shown to get another buy going still?
Yes,it´s true.2x24v AC will get ju about 2x33v DC.Isn't it true that if your transformer delivers +36/0/-36 AC you will get roughly +50/-50 DC rails, depending on the efficiency of your diodes?
2x26v AC will get you 2x36v DC.
But I don´t know,I read in the Sequel thread the 50v gave less distortion.Maybee the konstruktor can tell if it´s so.
Well maybe it´s a god idea to start a new thread about this,anyone would like the plesaure of doing it?
Want boards for Symasym AAK Version? Sign up for run nr2
Write in the thread how many and I´ll sign you!
Symasym AAK Version Run 2
I'll do it.
Hi Ryssen,
You should of received payment via paypal yesterday from email address regaliatech@yahoo.com, instead of alsaudiokits@yahoo.com. I changed the address a few months ago and forgot about it, my mailing address is still the same.
Thanks,
Al
Thanks,
Al
- Group Buys
- Pcb group buy Symasym, AAK modell
