peranders said:What does it mean in numbers? What is a high capacitance cable, I mean to regular ones?
The numbers are represented in pf capacitance per meter.
Don't remember the exact numbers of Kimber 4TC and 8TC (double capacitance of 4TC!).
Google a little and you'll find it.
The construction of the cable (crossed) gives it mid to high capacitance.
Low capacitance cables are figure-of-8 or flat cables, like Nordost and others.
That's why I initially had better results with cheap Supra 2.5, these chips don't like capacitive loads.
It's sorted, and I'm sure that if my amp works very well with a 5 meter pair of Kimber 4TC, it will work with almost everything.
The safety circuits has nothing to do with the sound (or?) but I haven't got those because I think this integrated solution has got very good properties when it comes to reliability. Has anybody broken a correctly connected LM3886, LM3875, LM4870? Please report!Peter Daniel said:It is very conservative approach, with a big concern on safety of operation and proper interfacing. It seems like sonic perspective is a little overshadowed
Pavel is right though: The parts cost nothing. They only take up a little space.
I am really looking forward towards a FAIR(and I do stress that) face to face comparison between a 47 style GC and a Pavel style GC...
Of course I would like to have a better design coming from europe, but I don't care where it comes from if it sounds better(us, canada, china, europe or any other place on earth) and doesn't cost a ton on c@sh nor does it consume 100watt+ at idle.
4 TC 144 pF per meter
8 TC 328 pF per meter
It means capacitance in a normal room of < 1 nF. Isn't this "small"? Nothing to worry about?
Peter Daniel said:I dropped my amp from second store window, and it still working
Cooling it at the window?
That's high.
It's for one meter cable.
Problem is most other manufacturers don't give you those specs.
An amp should be able to take 100 nF, or at least 10 nF without problems. If not redesign it.carlosfm said:
That's high.
peranders said:An amp should be able to take 100 nF, or at least 10 nF without problems. If not redesign it.
Tell that to National engineers.
I'm telling you that with direct output the amp sounds bad with these cables.
I'm telling you that with zobels it gets a little better, but not perfect.
I'm telling you that the solution I have is the best I found and solves it.
And I'm tired.
Gotta go drink a cold beer.
Note: not every amp works fine with Kimber speaker cables, you know?
Or other high-capacitance cable.
And sometimes you change the speaker and the problem is gone.
Is it only the amp?
No.
Do you have answers for everything, P-A?
No.
Upupa Epops said:cables : after many listening tests, which we do here, absolutely best results give hf power coaxials, such as Andrew and similars, belive or not .
Interesting, but that reference is too cryptic for me. Is there another description for "hf power coaxials"? Sorry if this is dumb question.
Sheldon
Edit: Turns out that was a somewhat dumb question. Found it by searching Andrew Coaxial - duh. Ok, so here's a not quite so dumb question: Which of their cables are you referring to? I'm assuming the 1/4" variety?
Yeah, no use in trying to redesign the wheel right?
Why not if you have control of the roads too?
Sheldon said:Turns out that was a somewhat dumb question. Found it by searching Andrew Coaxial - duh. Ok, so here's a not quite so dumb question: Which of their cables are you referring to? I'm assuming the 1/4" variety?
Andrew cables apparently were the basis for the well regarded JPS cables. They have a solid copper shield, so are not easy to handle. The center conductor is a copper/aluminum solid wire, which shouldn't be trusted in most circumstances for audio. But it seems to work. The LFS5 is a good place to start.
That Andrew cable is mostly used for radio antennas, so getting a few meters to try shouldn't be hard.
If you follow the instructions on TNT's article written by Thorsten Loesch, using a coaxial cable to build a speaker cable, it's only a matter of replacing the original for the Andrew.
Such arrangement has a very low capacitance.
Carlos
And do not forget shielding effect of the coaxials. All of that HF mess is best avoided or supressed. Terminating resistor at speaker box terminals also helps, as speaker + crossover+wires are inductive in HF range. May sound silly, but greatly reduces HF mess at the speaker cable terminals.
These guys seem to stock Andrew cable and sell by the foot:
http://www.cablexperts.com/cfdocs/cat.cfm?ItemGroup=11&itmsub=0&bskt=0&USA_ship=1&c=0
The type is LDF150. As you can see capacitance is low: 23.4pF/ft.
Price is reasonable, so it deserves a try.
There's a potentially even better cable, coaxial too, called Tflex 402. It uses teflon dielectrics and silver-plated copper. It's harder to find, but it's probably one of the best there is.
One of the few retailers might be this:
http://www.semflex.com/pdf/SM Series.pdf
Carlos
PMA said:Anyway, air would be even better dielectrics
Something like this?
http://www.antennasystems.com/pdfs/trilogy/plenum_catalog.PDF
Carlos
carlmart said:
Oh yes. Looks like a challenge
- Chip Amps
- Pavel Dudek's (Upupa Epops) LM4780 amp
