PA Discrete Class D Amplifier Schematic
Disabled Account
Joined 2005
This is working schematic. A Discrete Class D with 2 sets of mosfet at 90Vdc supply will give you enough power to drive 18" speaker at pretty loud.
Don't ask layout :)
Don't commercialize :D
Try if you like, as it is. Don't try if you doubt it.
Ltspice file is attached.
Kartino
  • DXT2K-UcD ver.3b - Final.pdf
Disabled Account
Joined 2005
The amp. All general discrete part can be found everywhere
Wanted to try this, sim first.
Kartino,
I am trying to simulate your design in post 1, for the purposes of the sim leaving out the protection and font end buffers, and am getting a completely intractable -12 or so offset on the output. I am also using 80V supplies as I have several transformers that would give that voltage after rectification and filtering. I have experimented with different transistor types but that doesn't seem to matter, nor does the offset adjustment seem to do anything.
Would yo mind taking a peek at the schematic and see if I'm just blind to a mistake or if you can offer some suggestions on ridding the sim of the offset?
  • UcD.asc
I did buid one based on OP's schematic. I'm however having some problems with it.
At +/- 90V, it seems to distort at about 20-30W output power and when probing with a scope before the output filter, it seems I'm loosing modulation for a fraction of a second - while the amp distorts sound.
Can anyone point me on what to check to fix this behaviour?
Disabled Account
Joined 2005
Please post your schematic exactly as real kit
