The h/w mode used and mac/amara. About The s/w mode I'm=0Do you use software for controlling the AK4399 ? I want to try in dual mono...
Dual mono Dac (separated box dac,pre-amp-power amp sitting near the speakers) was interested to try ,but to much times&budgets.
I still prefer the modded technique,better&over kill power supply good lay out and wiring material and good AC power system,the SQ of stereo dac still OK for my taste.
It can change for the sample rate and the type of regulator. I measure 155mA before any modification @44.1khz. If no modification, always under 200mA.
http://www.diyaudio.com/forums/digital-source/233926-new-xmos-usb-384khz-9.html#post3462689
Found the link to the spreadsheet if you want to add yourself - https://docs.google.com/spreadsheet/ccc?key=0AmX4TyHWgSmNdE5laDJQNlA3UVBYaWlrczJwYS1EcXc#gid=0
Excellent, thanks.
I was simply planning to get a second DIYINHK board for another project, but this does seem like a good chance to compare two similar boards.
On another note, has anyone using the DIYINHK board noticed a hissing sound in the background every now and then?
- Digital Source
- New XMOS usb 384khz
