Re: New projector from India !
well, if you are located at Canada, then I think 3Dlens.com should be the place near to you.
cool 1 said:Thanks Maks !!Where would be a good place to buy this could you please post some links.
Signing off the project
EUREKA..!!!!!!
Frens... I am done with my Projector. I managed to fix the foggy patch and waves problem on this weekend.
It took me just half a minute to fix it. Shielded cables, Connectors, Ground connections, LCD power supply... nothing was changed. Just a small addition and voila... it worked wonders. All that I added was a Anti-glare glass - the one that we use for computer monitors. If I slide through the glass at the light source, the patch and the waves go away instantly. The moment I remove it, the problem is there. It also keeps the heat from reaching the fresnels and the LCD. I dunno how I got this idea but it worked for sure... and we enjoyed watching movies on the BIG screen this weekend.
Visit my website for construction pics and please do make sure to leave a comment on the "Comments" page.. The URL is as follows:
http://macxpages.tripod.com
Note: The tripod site limps sometimes. Please be patient while it loads. Can't expect much from the free stuff.
EUREKA..!!!!!!
Maks0001 said:
Hey Yousuf... I'm from B'lore too.... I have just managed to finish my PJ. When I was arranging for the spares, I could not locate any dealer in B'lore... maybe, I dunno B'lore well. So I got it from Pune (Lensel Optics) with the help of a fellow DIYer.
Cool...can he help me too!
Btw, where are you located? I really like to see your PJ. I am near Indirangar.
Yusuf
Yusuf
Yusuf, I am in Indiranagar too... off the 100 ft. Road.... near ADIDAS.
btw, I have just posted a new post on the group, and also the URL of my website: macxpages.tripod.com
We can meet on this weekend at my residence.
pollok said:One suggestion - If you use a plain surface reflector instead of the textured one as seen in the photos, your results should be much better. Is the lamp 150 watts or 250?
- Pollok
Thanks for the suggest pollok... will give it a try. The lamp is currently 150 watts. Will upgrade it to 400 watts (and a plain surface reflector as you suggest) at a later time.
pollok said:400 watts may be too hot Maks. Without proper heat resistant glass it may damage the lcd and fresnels. Should be very careful.
Yes, Pollok.... am aware of that. I will work out a adequate cooling and heat resistant system for that... the reason why I said in my post that I'll upgrade the lamp at a later time.
Thanks buddy... well the said distance is 330mm.
cool 1 said:Maks great pj what is the distance between the LCD and the projection lense ?
ilango_slk said:Nice Job Maks, Glad to see more DIYers from India.
Thanks ilango_slk...
ilango_slk said:Just curious to know how much you paid from the MH setup? the fixture and the blast??
I paid Rs. 2000/-. It's a bit costly here in B'lore, but I didn't had a choice.
pollok said:I bought the 150 watt mh lamp with the ballast and fixture for Rs.1170 here in Hyd'bad
That's gr8, Pollok. I know B'lore is costly in all terms. Agreed that OSRAM lamps are a bit costly than others, but I feel paying Rs. 650/- just for the lamp (excluding Ballast and fixture) is definitely not the way to go. What make is your lamp, btw?
diarav said:I stay on Old Madras Road and will drop in some time to take a look at your work
Sure Din.... You are welcomed anytime to my house. And thanks for your kind words, buddy.
Maks, This bulb is Halonex I think. Coz the box is gone (!) and the letters on the bulb have disappeared due to the heat and handling. The shopkeeper recommended this saying this has 1 year warranty and is cheaper than Osram. I don't remember the individual rates of ballast, fixture and the bulb. Altogether it came to 1170.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- NEW projector from INDIA
