Answer to your question "yes you can".
Thanks, asking because I'd like to run it without the Kali on a piZERO, and on that I purposely do not connect the 5V or 3.3V pins. Just a convenience thing, would like to verify before trying it--
@cdsgames:
Just received the Kali and piano 2.1 dac. Before I hook things up to a raspberry pi2. On the piano dac, both switches in on position, but what to do with the Kali hat switch: on or off? Makes sense to set in the on position...
I've got mine 'on', and it works! I don't quite see why the switch is needed?
John
Allo probably trying to be compliant with HAT spec by having EEPROM on board .....
They have an EEPROM? The new beta Digi+PRO has one and is set, it magically shows up without specifying an overlay in /boot/config.txt-- also hifiberry has a tool to program the Dac+PRO... and that works. I had to set a flag to ignore this (to use the slave overlay)
Just mentioning it/FYI-- the Digi+PRO's first I've seen this in action... and works nicely.
Right now it does not matter the position of the sw.
@cdsgames:
IOne odd thing is that when I touch 'Pause' the last second or so of music repeats 3 or 4 times before the player goes into pause. The same thing happens with Kali + Mamboberry LS (not sounding quite as good as Kali + Piano btw). I've seen reports of the pause issue also happening on Volumio with Kali + Piano, so it seems that the common factor in this is Kali.
I've just experienced something very similar, rebooting the PI whilst still playing music. Instead of the music stopping when the squeezelite process was killed, music was looping (a second or so of music) until the power was pulled......
It will be something to do with the buffering of the input stream and the routine that empties the buffer.
My memory is very hazy of the time I was writing IBM assembler code emptying a "circular" buffer in the 70s, but this sounds familiar.
OT: Where is your "camel/racehorse" signature. I'm not so good at remembering forum "handles". But your signature I recognise straight away!
I've found that the looping happens at a faster rate when upsampling is engaged.
John
We are aware of the issue for the past week...this is why we delayed shipping a few days to test and make sure everything works.
Shipments are on the way.
Not sure I understand. This "looping sample" issue is on the replacement Kali that you sent me, not the original. You've sent another one, a third unit?
So, the bugs/issues reported with the 1st Kali you sent, 16 bit left/right channel swap and non-working 352k8/384k support, are confirmed fixed with the second unit you sent me. But outstanding now we have, firmware needs to monitor both left and right channels for zero detect, rather than just left, and this looping sample issue, when there shouldn't be any output at all from Kali?
That's correct.
@ cdsgames
i received my Kali a few days ago and i have the "looping sample" issue.
Will i also get a new unit or is there an other option to fix the issue?
My order number is 293.
On my Piano 2.1 the MUTE 1+2 LED are always glowing (not bright) but visible.
Is this normal?
puxxi2003
Is this normal?
puxxi2003
Yeap you will. Wait for an email from CS
Regarding Piano yes its normal.
@ cdsgames
Is this normal?
puxxi2003
Greg, Scott, or maybe someone else..... Is there anyone who has both the capability to build and use my rpi-4.4.y-simple git source branch and suitable hardware eg. 2.1 subwoofer, or wants a 2.2 (active crossover, l/r high-pass + l/r low-pass) output to test from Piano 2.1? PM me, please.
Guys, thanks for the offers to test the "full fat" Piano driver with 2.0/2.1/2.2 options and selectable low/high pass crossover frequency. Allo are still tweaking the driver and clarification is being sought regarding the license for the release of the DSP firmware created by TI PurePath software. As soon as there is something ready for wider testing, I'll let the people know who already expressed an interest in building from source and testing.
- Vendor's Bazaar
- New FIFO buffer for RPI/SBCs
