Cough, cough. I wasn't going to go there, because people look at you sideways when you praise a powered plastic P.A. speaker for its sound quality. But since you have plowed ahead, I'll follow in your wake.
...The K8 is one of the rare speakers that has startled me into thinking someone was talking right beside me. That's happened with FM radio voices and also with a live mic. Not many speakers do that.
Wow, it's nice to hear that I wasn't totally off base. I didn't notice the K8's sounding quite *that* good, but hey, my listening room is far from ideal.
That said, I found the K8's just didn't sound "beautiful." I guess I like a bit of euphonic sweetening in the sound, which would explain why I like vinyl and triode amps, while many very knowledgeable listeners think that's just stupid. That's a taste thing, and...
@tcpip, that is where the difficulties lie. How can you know what someone else's tastes will be re: this kind of thing? Super-accurate but possibly 'cold' sound? Or not-so-accurate but a 'warm' sound?
PS -
Honestly, if I were blindly suggesting a setup, especially for a small room where you're almost listening nearfield, I'd probably go with either the LSR305 or LSR308 for speakers (with an added bonus that the amps are done!).
Pick a decent source (bonus if it's balanced!) and enjoy.
DPH, have you heard the QSC K8 speakers? If yes, how do you think those JBL LSR308 monitors compare?
No, in this case, the source is not going to be a CD player, because she has very few discs. She'll probably be either keeping copies of digital audio files on hard drives, or listening to streaming audio over the Net, I reckon. Maybe, if she falls in love with music, she'll start buying CDs later, and then she can think of a disc spinner.If this is a first system, the source would likely be CD, or local files on a server. No need for a preamp in that case, direct from sound card or DAC to speakers. Be easy to set up for her...
I can see where you're coming from.Hi tcpip,
I'm going to recommend against powered speakers. You're locked into that speaker, and only one pair in case she wanted built in speakers in the kitchen (say). That's exactly what I did here, speakers for my wife and she loves them. A good preamp can easily cost the same money as an integrated amplifier anyway.
Strike 2 for the powered speaker. Vibration and often the ventilation isn't very good. I can't see her liking class D amplifiers if she likes music.....
But honestly, since this will be her first good audio system, and she's comfortable with the financial risks involved, I'm just going to encourage her to listen and decide for herself. She's perfectly capable of handling the usual consumer-support issues like getting the dealer to honour a warranty if there's a fault, etc. If she likes a passive speaker pair, she can go that way and we can help point her to the amplifiers to try.
There's only so much one can do to de-risk a friend against her choices, and she understands that. (Thank God for old and sensible friends. )
Actually, I'm not worried about this issue at all. I'm not choosing for someone. I'm just setting up things to guide someone to choose for herself. I'm only going to do technical sanity checks like "get half-way decent stands" or "you'll need X cables of Y type", or inputs about speaker placement. Other than that, it'll be her choice. I've already told her about Rogue Audio -- she may go for a valve amp, I wouldn't know. So, her speaker choices too will be hers alone.@tcpip, that is where the difficulties lie. How can you know what someone else's tastes will be re: this kind of thing? Super-accurate but possibly 'cold' sound? Or not-so-accurate but a 'warm' sound?
Are you referring to the B2031? They're supposed to be superb even if you ignore the ridiculous Behringer-style pricing.Good value for money, the K8!
How about the Behringer powered speakers? How do they compare to QSC?
I have not directly compared the K8 to the Behringers, so can only say I liked the K8 better without an A/B. I have done A/B tests (blind) between the K10 and the new JBL Eon 10. Easy to pick which is which, but almost impossible to pick which is better. That is surprising. I still like the K8 better than any of the 10" woofer PA speakers. And I'm a fan of big woofers.
Rongon, I think the "electronic" sound you were hearing is the DSP, not the amps. All these new little speakers use DSP, and they all have a slightly processed sound. The Focal do NOT have that sound, at all. Very sweet, very natural. They should be, considering the price difference.
As for Class-D, I'm going to disagree with Chris. I've owned, built and sold quite a few Class-D amps and they are better than just about any Class-AB amp I've heard. Yes, Class-A tube or sand can sound better, but Class-D is catching up. That's not what is holding back a system.
Those Focals i suggested earlier use Class D for the bass and A/B for treble .
As for Class D i think a lot of " traditionalists " have a difficult time accepting them ( no offence intended to anyone ) and letting go of older more conventional designs , i know i did , but the performance
of some ( subjectively ) for me,compared to some of the " monsters " i've used/owned over the years, amazes me especially when cost is factored in .
Now for the real issue. The audio signal between the preamp and powered speaker is now a shielded cable. That audio signal can range from magnetic cartridge levels up to a few volts peak. You're going to hear any interference that is picked up. Depending on your area, this may or may not be a problem. I wouldn't want to try and hide a signal cable compared to a speaker cable. The signal cable is also more susceptible to damage compared to speaker wire.
-Chris
That is kinda back to front on almost every level.
Balanced connections by their very design eliminate any interference the cable may pick up.
With balanced connections cable length only becomes an issue if it exceeds 50m or more, I've seen line level signal pass through 100m+ without problems although I wouldn't recommend that for microphones or cartridges. Speaker cable length is an issue almost regardless of their length.
I've seen decent balanced cables survive in studios and touring for years. That equates to a few human lifetimes of domestic use.
There are reasons that were analogue signal integrity is critical you will find almost exclusively balanced lines.
Actually, home use may be exactly the problem you haven't seen. At live gigs, you lay out the cables and put gaffer tape over them. You check them after every show so you aren't using a bad cable (having done live sound myself for years). The issue at home is that they are laid out and are constantly exposed to wear without gaffer tape to hold them down. I can't think of anyone who wants a balanced mic cable on the floor of their listening room! It's larger than a #16 GA speaker wire and much less flexible unless you go for an expensive, but wonderful Canaire cable.
Wear effects aside now, Charles Darwin, the signal levels in a balanced cable are still on the order of mV for quiet but audible music details. It doesn't take much interfering signal to generate those levels. From what? Any computer or laptop, a charging smart phone or tablet. Some new LED lamps. All these things are generally not found at a live sound gig, but they are extremely common in the average home.
I'm not saying doom and gloom here, but you have to accept that these things are a possibility. Besides, home balanced gear is often very high impedance. The pro stuff I was used to was not 600R, but it was lower impedance than the home stuff. In servicing some of the home studios out there, I have run into older mic cables that were straight up defective or intermittent due to being stepped on over a period of years. The one signal (aside from a TT) that you shouldn't run long distance, given a choice, is the preamp to amplifier signal run. It's just not good design practice unless you are checking your gear and cables (Pano) every week. Of course, a live sound event is so far removed from a static home setup that you shouldn't read across those things that work in live sound. Not for long term use anyway.
I expect some will disagree with me on that, and that is fine. But you can not say there aren't some of these issues I brought up in play. At least consider this instead of believing that you will not run into these issues. Remember, you are recommending a system for a non-technical person to live with.
I almost forgot. Powered speakers need a signal cable as well as a power plug to each one. That alone might be a big problem.
-Chris
-Chris
The main reason for the existence of balanced lines is their immunity to interference.
I had terrible interference problems from an old (then new) flat screen monitor which made it impossible to use the computer and the stereo at the same time and I could always hear the fridge kicking in.
Every hint of noise disappeared the moment I eliminated the last single ended connection in my stereo. I've been using the same balanced cables for 15 years or more at home without any faults or problems whatsoever.
As for non-technical people I find XLRs a lot easier than other solutions because a male is always an output and female an input. Foolproof really.
If she is serious, and doesn't mind traveling about 5 hours north in Vancouver, BC there are many more (and better) hifi shops. And the US dollar is very strong vs the Canadian dollar right now.
Seattle (about 3 hours north of Portland) also might have better shops...magnolia at Best Buy will have B&W, etc but they won't know anything about them and won't have good amps to demo them with. They are also less likely to bargain on the price.
It's been a while since I've been to Portland so Iam not familiar with the hifi shops there.
Yes, this is the sort of impression I too am getting, sitting in India and Googling for dealers. There are good, knowledgeable dealers there, I'm sure, like Echo Audio and one or two others, but I am not sure she'll get to hear all the models we're talking about.If she is serious, and doesn't mind traveling about 5 hours north in Vancouver, BC there are many more (and better) hifi shops. And the US dollar is very strong vs the Canadian dollar right now.
I'd like it if she could at least get a chance to listen to 2-3 really top-notch systems as part of her exposure to systems and their sound. It would change her thinking forever.
Let me see what she finds. Maybe she is open to a Seattle trip sometime too...
Oh, I'm trying But she probably has little free time. She's a hot-shot senior scientist at a giant company, plus a wife and a mom to two great kids... You can imagine.Hi tcpip,
Have her take her time. It's worth it.
-Chris
I like the looks on the Oppo HA-1, it's off on the price point but it's a dac and pre-amp.
https://www.oppodigital.com/headphone-amplifier-ha-1/
Hi Charles Darwin,
And as a last resort, I took a two story jingle studio from balanced to single ended. That got rid of their radio interference problems. It also make "0 VU" read the same on all their equipment. That was over ten years ago - 20 in fact. They are running fine.
Balanced is easier to get signals from one place to another with less (didn't say no) interference than a simple singled ended line, but that isn't always cast in stone. Had a music recording studio that going to full balanced for everything (outboard gear included) didn't help. Even tried the pin 1 problem fixes. Moving the 24 track did the trick.
So while using a balanced line normally can help, that isn't always the case. The doubled shielded single ended cables are also good medicine. Was your equipment on two different phases by chance?
-Chris
-Chris
- Member Areas
- The Lounge
- Need help to buy a system -- Portland, Oregon
