Humm
I have finished the amp, thanks to all who helped. I have found one lingering problem which has me puzzled. The amp has no hum except when I plug in my iPhone (any iPhone) then it is annoying. I've changed connecting cables but no change. Does anyone know how to fix this or what the problem is?
With or without external power supply? If with, could be hum loop.
I have a doc station and I can plug in the iphone directly or through the doc station. Both are the same. Each hum.
I understand that the push-pull negative feedback amplifier design was to remove distortion. Can someone explain where the distortion exists that it minimized and how it minimized it?
BTW I found the source of the hum in the previous post. It was in the PCB groundplane, put there by the pwr supply. Hooking up an input signal from the iPhone (or anything) connected the ground with the humm to the input. I just took the pwr supply ground off the PCB groundplane and the problem went away.
For a given device, even-order distortion stays the same even if you invert the input signal. This is elementary maths (powers and trigonometry). Push-pull has two devices, with one input signal inverted. The output transformer subtracts the two signal it sees: wanted plus odd-order are antiphase so add, even-order is in phase so cancels.
Alternatively, look at combined push-pull valve curves. The two sets of curves are bent in opposite directions so cancel out. Either way of looking at it, P-P cancels even-order distortion but leaves odd-order unchanged. Fortunately even-order is higher for all devices so the total is reduced.
- Tubes / Valves
- My Wave Isn't Square.
