My Take on Threshold NS10
Official Court Jester
Joined 2003
Stabist said:
hehe - I've realized from where my confusion :( Silly me :smash:
Ofcourse - I should be more careful with datasheets where transistor is drawn 3 views :angel: (ground plan, side view, ...)
Geee, feel sooooo stupid :smash: :cannotbe: right now :bawling:
I always draw notes on paper in my usuall habit-legs to me,face down,if necessary.
hehe-I made mistakes more than once ,before I make that habit
hehe - the mistake I made was - I've done notes and sketches of placement of components - from top view (and marked legs) - and then opened Philips's datasheet - where ofcourse legs are marked as looking it from bottom; then opened another datasheet (with 3D drawing of transistor) - and ofcourse now I had "different markings" hehe :smash: :smash: hehe ... nice school for next time :angel:
Joined 2003
just half
not tried yet
series reg part (left part from dotted line) shared between channels
317 CCS and shunt for each channel on chared pcb (reg+audio)
edit- 50mA per stage
Joined 2003
steenoe said:
Are you going for the shunt reg? I hope you are indeed, just to see if it works for somebody else. (I had a little trouble with buzz as you remember if you read the whole thread:xeye: ) You can keep a shunt reg pretty small as you can see on the pics I posted earlier. The sound of it is just great:)
Steen:)
lalalalalala........
I don't have buzzzzzzzz
lalalalalala.......
:dead:
:devilr:
:clown:
choky said:
hehe
you can't
:devilr:
Hehe - do you wanna bet :devilr: :cool: ;)
I'll try it out with shunt reg probably in next version/attempt - because right now what I have at hand is a bunch of LM317/337 ...
Which schematic did you use for your regulator?
choky said:
just half
not tried yet
Hmm - as a start I wanted to build similar version as your series reg part (double series regulator) with additional power resistors at the output to have constant load ...
but now - this seems tempty :) (but I'll have to buy some parts ...)
Btw - trimer - if decided not to use it - do I just simply connect emittor of Q1 directly to -V?
Joined 2003
steenoe said:
Did you calculate the resistor values for the 431 device? I am also curious how you would connect that device to the negative side.
Steen:)
didn't calculated yet resistors
connecting?
like zenner-
exactly the same,just final resistor chaaaaaaaange place
:Popworm: :wave2: :crazy: :emoticon: :headbash: :headbash: :joker:
tip for steen:
minus is always minus
plus is always plus
what you'll call ground
that's your choice
if you are good at it
components will agree with your choice
:devilr:
mods!
where's mine "reinventing the wheel" smiley??
connecting?
I would like to see a working schematic;) I did connect the 431 as you say is the obvious way, but but but.......
Well, I want to discuss the main supply a little more. I just went through some boxes of (big surprise!!) electronic stuff and found this. Take a look at the pic. Isnt that a mains filter of some sort?
Could I try that in front of the trafo? Ofcourse I could try, I know that:D But would it be reasonable?? Any chance it would cancel out the darn buzz??:)
Steen:)
Joined 2003
steenoe said:
Here is another from the rearside. As you can see on the tracks, it was made for heavy duty:) I would appreciate it if someone could tune in on this.
Steen:)
bingo!
nice one
side with three legs- one is line,middle is ground,other side is neutral (in my country line and neutral are interchangeable,meaning that wall outlets and device plugs are not .....hm...phased-if that is proper word.
other side-with two legs -is output to load ;one line,other neutral
try it,immediately
tomorrow I'll try to fiddle with negative 431 and post
in a meantime ,one example
http://www.diyaudio.com/forums/attachment.php?s=&postid=766245&stamp=1131941055
