Joined 2002
What about the extra boards i ordered ? You should have a extra external hard drive that backs up your main drive / drive's still have it back up every few days in the middle of the night just because you have raid doesn't mean you will never loose your data. I have a external hard drive that backs up at night time when i'm sleeping. In the morning when i arrive at the machine it tells me back up successful or not. maybe buy a maxtor one touch something simple with a usb2.0 or FW400.
Jason
Jason
jleaman said:I have a external hard drive that backs up at night time when i'm sleeping. In the morning when i arrive at the machine it tells me back up successful or not. maybe buy a maxtor one touch something simple with a usb2.0 or FW400.
Yes, this is what I do. I have found RAID on desktop PCs to be not so reliable. An external drive is the way to go
I am placing the order tonight! Please order today if you would like to participate.
What is available
MOXlite - $8 - 2 bandpass, 1HP, 2 EQ, regulators
Opamp - $5 - 8 discrete opamp boards
Shipping - $6 USA, $7 Canada and rest of world
Please note that the board will NOT have onboard pots. Delivery to me is ~May 16th, I will ship all boards the following day.
http://www.anidian.com/audio/construct/mox_order.shtml
Thanks everyone!
What is available
Thanks everyone!
Joined 2002
Thanks kepa1--you beat me to it. A little more info that I had already typed:
The discrete boards are a totally optional discrete opamp design that is also compatible with MOXlite. The price includes only the boards -- enough for 8 single or 4 dual opamps. There are no surface mount parts.
I don't really recommend the discrete opamp for novices. It is (relatively) expensive, and I think time and energy would be better spent optimizing other areas. But if you want to build your own opamps, it is a nice way to try it out. The 2SK389 is hard to beat as an input stage.
Joined 2002
jleaman said:Im not a novice. : O ) I have a 290$ soldering station that does SMD part's..
Having the tools and having the skills are two totally different things.
Tell me Jason are you still looking for a decent soldering iron for conventional work? I priced a model out for $89 CAD that has great potential.
Anthony
Joined 2002
Coulomb said:
Having the tools and having the skills are two totally different things.![]()
Anthony
Yes i do need one.. What does it look like ? what make what model ?
I will try to get the details for you and send them to you in a few days.
Anthony
Joined 2002
These are probably great buys:
http://www.diyaudio.com/forums/showthread.php?postid=622654
I have one of the cheap Chinese ones that MPJA sells...I think it is fine. A nice selection of cheap tips available.
The order is in! There were a total of 87 orders. I'll be donating at least $1 a board to DIYaudio once I get I verify the orders are correct.
I should receive the boards on or before May 20th. The annual is coming.
I've ordered additional boards, so I'll continue to accept orders as long as I have boards available. Thanks everyone.
Joined 2002
- Group Buys
- MOX active crossover buy
