I can not say much about it. I am not the designer.
Send Andrejs an e-mail.
I mean I don't think there is much to that "desing" it is just a tube rectified supply with a zener regulator.
I am wondering if it will be noisier than using battery.
Tonight, if I get a chance I want to compare the battery to a good wall supply with audio transformers, blackgate caps and series regultaro stage followed up by the shunt and see if this betters my "reference" batteries.
OK, Merlin, i see the problem.
The upper transistors should be PNP ( BC560C ) and the lower NPN ( BC550C ).
Attached CCS schematic is now OK?
Joachim, I have to say, that is beautiful work there on your preamp. I will probably never (never say definitely never ) take on a project like this simply because i'm all digital for transport, source and crossover , but I appreciate great execution and dedication to projects of all types.
well done!
it always is and this is a completely flawed comparison, should we compare the batteries to the raw unsmoothed bridge output? the fact that batteries, perhaps with basic passive filter afterwards can do so well without regulation, particularly on more constant current loads, says a lot. batteries necessarily result in fairly long, inductive connections, so for more dynamic loads its really not a far comparison.
well done!
Perhaps you are right and the comparisons I saw were of a regulator vs standalone battery.
I know at least one person who tried supplying the Paradise using batteries (that means, 26V battery voltage as input for the CCS-fed shunts), and he mentioned an improvement - not big, but audible.
Perhaps grid-fed power supplies merit further analysis for both noise isolation as well as dynamic capabilities.....
Joachim Master pre-pre is going on with your CCS, NO NOISE thank you.
are you using that for preamplifier? interesting! I was thinking of giving it a try for preamp as well, not sure.
Where would you control your volume and what OS are you going to use?
Yes, i definitely with look into tube rectifiers.
Too bad i gave my good RCA tube rectifiers to Frank Schröder.
No need to worry, I'm more than happy to return them for a good cause ;-)
Give me a ring...
Frank
Cool, anyway, they are in good hands.
When i build a ( tube ) phono stage with them you will be one of the first that will hear it.
I have a circuit diagram from Borbely that i posted on the Frickelfest Forum that has to be build. It is super simple and very clever i think.
I never thought that i will go back to tubes but my own design i used on the Frickelfest and the comparison we did at your place ( early MPP against your reference tube phono )
convinced me that there is potential.
Give me a ring...
Frank
Hi mr. Schroder!! I have heard wonderful things about your products nice "meeting" you...I am a big fan
I my self have really been impressed by one tube phono, it was the klimo top of the line phono (can't remember name of model but I don't think they make a lot of items).
It was very 3D dynamic and colorful! A very, very fine phono stage.
I always compare my solid state effords with tubes. It is a good reality check and mature technology. Tube stages tend to be simple too ( the amplification, PSU can be very elaborate omn the other hand ) and i like simplicity if possible.
so basically you thinks tube sound is more reliable?
- Analogue Source
- Masterpiece
