A midRange TL, done well, will flatten impedance and "suck the back wave away"
dave
If done well... Do you think that's something i could do inside that box?
Sucking the back wave away, what are the benefits?
You'd have to get quite creative to fit a TL inside the ML-TL oriented with the narrow side as the baffle.
If you can suck the back wave away then none of it comes back thru the cone, eliminating time-smeared extraneous signal from being added to the music.
dave
dave
Quite creative, what's the problems i would be facing?
The reward sounds fine. It sounds like it's well worth spending a couple hours on it.
These speakers play hiphop well. One might not think that a 4" full-range speaker would sound good to hiphop but it does.
Caught In The Hustle (Bonus Track) - Immortal Technique - Spotify
The bass sounds like from an 8" woofer or something. I can't play that super-loud but quite loud and it sounds good. There's no really physical bass, but it is definately audible
Quite impressive. The drivers barely move but it makes loads of bass
The larger woofers like the Eminence 15" is tempting.
I've read about the dry and nice bass by people using them. That's something that would certainly be nice. I can live with not having full pressure to <35Hz. The bass depth in the EL70 are pretty okay (maybe a little deeper would be nice) but i lack the headroom.
And since i guess they require a box the size of a house it might be able to use it as stands for the Mar-Kel70?
An offtopic but important question:
Do you think it would work well making a 6-8m RCA-cable with this one http://www.blekingebilradio.se/PICTURE/9726-14-impact_cable_ip001.jpg
I don't want to pick up russian radio signlas with it or any background noise.
Edit: It costs around $3.15/m and it appears to be a mono cable i think.
Some small differences in the woofers. The TL was designed for the dark cone, but works (really) fine with the white.
dave
Dave,
Have the opportunity to get Woofer #6. FR unit will be either CHR-70 or CHP-70 (can be EL70 also if that helps).
If there is no problem otherwise, want to go for the dark cone.
Thanks,
Zia
Dave, has any guy contacted you about plans? Not Max, but some other guy.
I have uploaded a video on YouTube of my Mar-Kel70 playing some music and some guy sent me a message wondering about plans and if they're good to electronical music and so. I told him to contact you for plans and that they, in my opinion, work great for most electronic music
Just looked up the email, it was Max. Do you know if he was happy with the discount?
dave
Yeah, i think so.
Atleast i think it's a good idea. And $10 for the planset for EL70 is really really worth it. Even the ordinary price at $25 is a good price, in my opinion
Yeah, i think so.
There, it's officially out, a 60% discount to grade school students (K-12 here in North America) on plan-sets. I'll need some sort of proof, student card, or a note from teacher or principal (on letterhead).
dave
The current CHP-70 (not the new one Mark is making) is interchangeable with EL-70 in enclosures?
No. Close but not quite. I haven't looked at them extensively and will likely concentrate of CHP70.3. The original A6 is interchangable with the EL70 in the mMar-Kel (large enclosure for A6, small enclosure for EL70). Appropriate driver fixing changes.
dave
- Full Range
- Mar-Kel70 in Sweden
