Low cost ES9018 DAC board GB
Check out the updated board, it now uses ADM7150 regulator as an option as well as TPS7A47 symmetrical power supply for the opamps.
https://drive.google.com/file/d/0B2ArnRLTrdN0dmNSSWptUmJaTmM/edit?usp=sharing
https://drive.google.com/file/d/0B2ArnRLTrdN0M3pNeWZJTmwteW8/edit?usp=sharing
Hi syllable,
Unable to view your images/files.
You may check your files' sharing setting in Google Drive.
Or just use tinypic.com as image-hosting instead of the problematic Photobucket.
1) syklab - 2 PCB, 2 ES9018K2M (pre-soldered)
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (un-soldered)
4) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
5) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
6) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered)
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
9) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
10) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
11) rredline - 1 PCB, 1 ES9018K2M (pre-soldered)
12) DaveK - 1 or 2 kits
13)OverkillAudio - 4pcb, 4 ES9018
14)cristi289 - 2PCB, 2ES9018K2M+oscillator (pre-soldered)
15)Turbon - 1 PCB, 1 ES9018K2M (pre-soldered)
16)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
17)Ryssen - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
18)vuki - 1 PCB, 1 ES9018K2M (pre-soldered)
10)number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
Check this attachment ...
19)number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
20)badrisuper - 1 PCB, 1 ES9018K2M + oscillator (pre-soldered)
Badri
Board $20, oscillator v$5, IC $20, if want the TPS regs soldered $17, you can also use LM based symmetrical PS if you want it is cheaper. You can also upgrade to ADM later even after populating the ADP if you want. Sounds damn good even with ADP and LM based PS.
Sent from my Q700i using Tapatalk
3) richard_pc - 1 PCB, 1 ES9018K2M (pre-soldered)
change to pre-soldered.
15)Turbon - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered)
Added TPS regs.
Ryssen, how many DACs do you own now The search never ends...
Well lets see now,theres the AK4396 and CS4398 and ES9023 (3 of them) and AD 1865 (that never got finnished..)and one ES9018 experimental board that I am going to use with the tube unballancer...So there´s a whole bunch of them..
I use the one ES9023 as Bas/mid and the CS4398 at the mid/treble and one ES9023 as SUB......
17)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered)
Added TPS regs.
