Low cost ES9018 DAC board GB
Obviously you cannot get the Crystek 950 for $5. Crystek 950 costs around $28+shipping. You can use it if you want. I have already mentioned the crystal oscillator in the bom posted earlier, kly refer that. I will place a dedicated 3.3v ADP on the bottom right corner.
Sent from my Q700i using Tapatalk
Hi syl.
Could you provide a Crystek 950 if paid for, mounted... Should be cheaper at volume :)
1) syklab - 2 PCB, 2 ES9018K2M , + oscillator + TPS regs (all pre-soldered)
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (pre-soldered)
4) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
5) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
6) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered)
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
9) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
10) atupi - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
11) rredline - 1 PCB, 1 ES9018K2M + TPS regs (all pre-soldered)
12) DaveK - 1 or 2 kits
13)OverkillAudio - 4pcb, 4 ES9018
14)cristi289 - 2PCB, 2ES9018K2M + 2 oscillator + 2 TPS regs (all pre-soldered)
15)Turbon - 2 PCB, 2 ES9018K2M + 2 oscillator + 2 TPS regs + 2 Crystek 950 (all pre-soldered)
16)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
17)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered)
18)vuki - 1 PCB, 1 ES9018K2M (pre-soldered)
19)number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
20)badrisuper - 1 PCB, 1 ES9018K2M + oscillator (pre-soldered)
21)dady - 1 PCB, 1 ES9018K2M + oscillator (pre-soldered)
22)axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + 2 Crystek 950 (all pre-soldered)
__________________
21)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
I added the Crystek 950 and the TPS regs
Best Regards
20)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (pre-soldered)
17)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
Added TPS and Crystek & soldered
Hiya
13)OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered.
I added the TPS and Crystek 950 and changed to all soldered.
Derek.
PS Would go for a duel mono if it was available.
23)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered)
(Added one set.)
Just want to confirm again:
a) This works in 24/192 I2S mode with default register values without the need for microcontroller, right? Will it also do other modes like 24/176, 24/384 etc. without the microcontroller?
b) All output-side opamps have DIP + SOIC option now, right? DIP alone is essential for me, since I plan to use discrete opamps.
20)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
I have added TPS regs and Crystek.
Badri
Okay, so we are near to 35 so I will start processinhg the orders. Currently there are only 17 crystek 950 in stock at digikey so if u could make the payment fast I will order the crystals immediately. All paid members should notify on this thread after payment. Make your payment to audiodesine(at)gmail(dot)com
I will list the price for the parts once more
1. Board - $20
2. ES9018K2M IC - $20
3. XG1000 - $5 or CRYSTEK 950 - $28
5. TPS regs x 2 - $17
Shipping charge for
First board - $10
Each additional board - $5
1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
1. Board - $20
Shipping charge for
First board - $10
Is 1,2,3 (Crystek) and 5 at $85 for 1 DAC set + $10 shipping ? Paypal fee included ?
