Ian asynchronous I2S and S/PDIF FIFO KIT group buy
I use the receiverPi with the jlsounds interface I2SoverUSB.
To automatically switch to the USB stream, I want to use pin J4-15 to the 5V of the I2SoverUSB USB part.
However, if I do this, I bring back the disturbances from the USB supply to the receiverPi via J4-15 and GND.
Is the J4-15 pin isolated?
Which GND connection should I use so as not to bring back USB disturbances?
If not, do I have to use an isolator?
nounouchet
I am upgrading the FifoQ3 Accusilicon AS338 clock .
??Accusilicon AS338 ???? ??? ??? Hi-End????-???
I sell various models of Accusilicon clocks, and I have no reason to deliberately say bad things about the more expensive AS338. According to my actual comparison between AS318-b and AS338, I don't think AS338 is better. AS338 will make the sound too clean, some of the original music details disappear, so that the sound becomes worse.
Yes indeed you can do that. RPI not needed if just using your cd as source
Thank you for the information! Will I need some extra power to supply this RPI + RecieverPi + Allo Boss Dac - Tower? Or will my current 5V 3A PSU be enough?
Another thing I would like to know how is it about the support of the RecieverPi?
Will it work with any OS like Volumino or Moode Audio etc?
My idea is to achieve a setup where I can seamlessly (or maybe with some source selection option in the software) switch between CD and stream i/o for my Allo Boss Dac.
Thank you !
The AS338 is out of stock I swapped for the cheaper AS318-B it sounds great. :)
Joined 2018
The receiver pi works stand alone and so the software you mention pertaining the Rpi....Moode or Volumio, isn't applicable. If you 'listen through the ReceiverPi the Rpi is doing nothing. It automatically switches from Rpi signal or spdif input.
.I believe the 5v is shared over the GPIO and so one 5v feed would power the entire stack. However you will benefit from separated psus.
1. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
2. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
3. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
4. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
5. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
6. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
7. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
8. Patjr 1A*1, 4A*1, 27A*1 28A*2 29A*1, Station Pi*1
9. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
10. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
11. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
12. Bartb 30A*1, 28A*2, 25A*2
13. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
14. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
15. Boldname 1*1, 2*1
16. Narukas 11*2
17. atiq19 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 9A*1, 10A*1, 12A*1, 13A*1, 21A*1, 23A*2, 24A*1, 9*1, 11*2, 12*3, 16*4, 20*1, 22*16
18. ittien 9x1
19. roubo 1A*1 9A*1 11A*2 12A*3 13A*3 20A*1 21*4
20. druidaudio 1A*1, 20A*1, 22A*1
21. roubo 2A*1 3A*1 4A*1 6A*1 8A*1 10A*1 13A*1 16A*2 19A*1 21A*1 23A*2 24Ax1 21*2 22*10
22. klweds 1A*1
23. VT67 1A*1, 12A*1, 20A*1, 23A*1, 24A*1, 27*1
24. luchoh 1A*1, 9A*1, 11A*4, 13A*4, 20A*1, 13*4, 17*8, 20*2
25. kirks 12A*2, 27A*1
26. Domg 12A*1, 22A*1, 23A*1, 27A*1, 28A*2, 29A*1
27. Joseacm08 21A-SMD*1, 28A*4, 30A*1
28. mksung 25A*2, 26A*1
29. Victhor34 1A*1, 20A*1
30. Heathkit 30A *1
31. sfleming 9A*2
32. clsidxxl 25A*2,26A*2,2A*2
33. bug2k11 19A*1
34. Raimundas 25A*1, 26A*1
35. Cerole 29A * 1 , 27A * 1 , 28A * 3 , 25A * 1
36. metronet 25A*1, 31A*2
37. NicMac 25A*1, 30A*1, 31A*1
38. stew1234 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 11A*3, 12A*4, 15A*1, 16A*1, 19A*1, 22A*1, 24A*1, 25A*2, 26A*1, 31A*1, 33A*1, 34A*2.
39. Aguaazul 1A*1, 3A*1, 4A*1, 25A*1, 26A*1, 27A*1, 28A*4, 29A*2, 30A*1, 33A*1, 34A*1, 35A*2
40. A123 1A (Q3)*1, 2A*1, 20A*1, 27A*1, 28A*3, 29A*1, 35A*1
41. _oxygen 35A*1, 34A*3
42. minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
43. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
44. erikovsky 1A*1, 9A*2, 13A*4, 20A*1, 22A*2, 23A*2, 24A*1, 31A*1
45. JimS 25A*1, 26A*1, 30A*1
46. Studley. 25A*2
47. SimonJ 1A*1 (Q3), 2A*1, 14A*2, 24A*1, 27A*1, 28A*6, 29A*1, 30A*1, 32A*1,
48. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
49. wealas 30A*1
50. linh0983 1A*1, 25A*1, 32A*1
51. Subbu K 25A*1, 26A*1, 30A*1
52. Karahana 3A*1, 4A*1, 6A*1
53. Patjr Ref. Line 8
54. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
55. Jack0k 1A*1, 20A*1
56. marcus1 - No longer required atm.
57. Photochum1 25A*1, 31A*1, 23A*1, 13*3
58. AirAir 20A*1, 21А*1, 23А*1, 25А*1, 26А*1, 32A*1, 33А*2
59. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
61. nounouchet 19A*1, 20A*1, 26A*4
62. wcwc 1*1, 2*1, 13*22, 19*1, 35A*1
63. cec 1A(Q3)*4, 9A*3, 12A*9, 20A*4, 22A*1, 23A*2, 25A*1, 26A*2, 32A*1, 33A*1, 34A*2, 35A*1, 13*12, 22*3
64. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
65. mnichols30030 25A*1, 27A*1, 33A*1, 34A*1
66. 18gb 1A*1, 3A*1, 17A*1
67. Morde 1A*1, 12A*1
68. bb870817 30A*1
69. judesu777 1A*3,3A*2,4A*3,7A*1,8A*3,9A*3,16A*2,22A*1,27*1
70. Pinnocchio StationPi * 2
71. Robin de Wolf 1A*1, 12A*2, 13A*4, 19A*1, 23A*2, 13*6, 17*6, 27*1, StationPi *1
72. Yatsushiro 35A*1
73. kenlaumm 1A*1, 5*1, 6*1, 10*1, 17A*2, 18A*1, 22A*1, 35A*2
74. Ghettocowboy 1A*1,20A*1,23A*2,35A*1
75. sernikus 31A*1, 32A*1 , 35A*2
76. druidaudio 11A*1, 13A*2, 23A*2, 35A*2
77. Xapri 13A*2, 22A*1, 12*1
78. TirNaOg (Q3) 25A*2
79. yannisdoc 7A*1, 33A*1, 34A*1, 28A*3, 26A*1, 25A*1, 35A*1, 31A*1, 27*1, 23A*2, 24A*1
80. ed linssen 35A*1
81. Big bird 35A*1, 7A*1, 27*1, 21A*1
82. kkla1016 1A*1 , 20A*1 , 22A*1 , 23A*2 , 35A*2 , 24Ax1 , 27x1
83. prohvesor 13A*4, 23A*2, 27A*1, 28A*4, 29A*1
84. Caad 30A
85. geoturbo 1A*1, 13A*6, 14A*1, 19A*1, 23A*2, 24A*1, 26*6, 27*1
86. adrian311 1A*1, 3A*1, 4A*1, 23A*2, 24A*1, 35A*1, 27*1
87. pz1 26A*1
88. titus2002 1A*2, 13A*8, 23A*2, 35A*2, 13*4
89. grarea 4a*1, 19a*1, 24a*1
90. STEDAV 12A*8 25A*1 26A*4 17*2
91. topicreader 25A*2, 26A*1, 29A*1, 35A*1
92. mahtew 20A*1, 25A*1, 30A*1, 32A*1, 33A*1
93. kvl 1A*1, 31A*1
94. Wirewiggler 25A*1,30A*1
95. Crom 1A*1,25A*4,26A*2, 30A*1,33A*3,34A*6,17*10
96. atom6422 13A*4, 24A*1, 25A*1, 26A*1, 27A*1, 28A*4, 29A*2, 30A*1, 31A*1, 33A*1, 34A*2, 35A*1, 3*1
97. samsie 1A*1,11A*3, 13*1, 17*8
98. Wirewiggler 3*1,35A*1
99. Alfista 1A*1, 3A*1, 20A*1, 22A*1, 27*1
100. themixmaster 28A*4 29A*1
101. Johnny Canuck 1A*1, 9A*1, 13A*2, 20A*1, 23A*2, 24A*1, 25A*1, 26A*1, 33A*1, 34A*1, 35A*1, 27*1
102. anry 24A*1, 25A*1, 33A*1, 35A*1, 17*1, 27*1
103. ke6fzi 1A*1, 9A*1, 12A*1, 13A*1, 20A*1, 23A*2, 24A*1, 25A*1, 26A*1, 33A*2, 34A*4, 35A*1; other items (19A*1, 31A*1, ...) & possible changes TBD
104. BrianGasberg 35A*1, 20A*1, 1A*1, 33A*1, 34A*2, 25A*1, 26A*1, 13A*4
105. tadek 9*4
106. 10y 1*1A , 4*13A, 1*30A , 1*31A, 1*22.
107. apotelyt 13A*4, 19A*2, 3*2
108. mvaldes 1A*1, 9A*1, 13A*4, 17A*1, 18A*1, 35A*1
109. sgledhill 35A*1 StationPi please.
110.judesu777 1A*6,3A*2,4A*2,7A*2,8A*2,9A*6,18A*1,19A*1,20A*3,27 *1
111. Eshatos 19A*1, 35A*1
ReClockPi is available for early order now
I’m sorry for keeping you waiting. I have been working very hard with my SMT supplier to make some ReClockPi production for early orders.
Please go to my gitHub to download the new updated order form if you are interested
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
User’s manual will be available next week.
I was trying to make the price a bit lower. But both materials and assembling got much higher recently. I’m sorry about that. Or, you can wait for my next GB for a ReClockPi special price, but I don’t have a schedule for now.
ReClockPi
by Ian, on Flickr
ReclockPi1
by Ian, on Flickr
ReclockPiFifoPi by Ian, on Flickr
ReClockPiFifoPiSinSquare
by Ian, on Flickr
Sck88JitterBeforeAfterReClockPi
by Ian, on Flickr
LRck88SignalBeforeAfterReClockPi
by Ian, on Flickr
Thanks,
Ian
