Michele,
To achieve your requirement, basically you will only need a FifoPi Q3.
If you BII is far from your transport, you can use a HdmiPi transmitter and a HdmiPi receiver.
StationPi would be a good option to separate RPi and audio gears.
For power supply you can use a LinearPi Dual.
Regards,
Ian
Regards,
Ian
Hi Ian, I'm not updated on the actual status of this project and I'm not sure on which part to order.
I would like to build a digital transport with RPi to connect to my Buffalo II DAC
Which parts should I order?
Michele, you could also check this out. It might serve as inspiration.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
1. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
2. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
3. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
4. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
5. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
6. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
7. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
8. Patjr 1A*1, 4A*1, 27A*1 28A*2 29A*1, Station Pi*1
9. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
10. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
11. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
12. Bartb 30A*1, 28A*2, 25A*2
13. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
14. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
15. Boldname 1*1, 2*1
16. Narukas 11*2
17. atiq19 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 9A*1, 10A*1, 12A*1, 13A*1, 21A*1, 23A*2, 24A*1, 9*1, 11*2, 12*3, 16*4, 20*1, 22*16
18. ittien 9x1
19. roubo 1A*1 9A*1 11A*2 12A*3 13A*3 20A*1 21*4
20. druidaudio 1A*1, 20A*1, 22A*1
21. roubo 2A*1 3A*1 4A*1 6A*1 8A*1 10A*1 13A*1 16A*2 19A*1 21A*1 23A*2 24Ax1 21*2 22*10
22. klweds 1A*1
23. VT67 1A*1, 12A*1, 20A*1, 23A*1, 24A*1, 27*1
24. luchoh 1A*1, 9A*1, 11A*4, 13A*4, 20A*1, 13*4, 17*8, 20*2
25. kirks 12A*2, 27A*1
26. Domg 12A*1, 22A*1, 23A*1, 27A*1, 28A*2, 29A*1
27. Joseacm08 21A-SMD*1, 28A*4, 30A*1
28. mksung 25A*2, 26A*1
29. Victhor34 1A*1, 20A*1
30. Heathkit 30A *1
31. sfleming 9A*2
32. clsidxxl 25A*2,26A*2,2A*2
33. bug2k11 19A*1
34. Raimundas 25A*1, 26A*1
35. Cerole 29A * 1 , 27A * 1 , 28A * 3 , 25A * 1
36. metronet 25A*1, 31A*2
37. NicMac 25A*1, 30A*1, 31A*1
38. stew1234 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 11A*3, 12A*4, 15A*1, 16A*1, 19A*1, 22A*1, 24A*1, 25A*2, 26A*1, 31A*1, 33A*1, 34A*2.
39. Aguaazul 1A*1, 3A*1, 4A*1, 25A*1, 26A*1, 27A*1, 28A*4, 29A*2, 30A*1, 33A*1, 34A*1, 35A*2
40. A123 1A (Q3)*1, 2A*1, 20A*1, 27A*1, 28A*3, 29A*1, 35A*1
41. _oxygen 35A*1, 34A*3
42. minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
43. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
44. erikovsky 1A*1, 9A*2, 13A*4, 20A*1, 22A*2, 23A*2, 24A*1, 31A*1
45. JimS 25A*1, 26A*1, 30A*1
46. Studley. 25A*2
47. SimonJ 1A*1 (Q3), 2A*1, 14A*2, 24A*1, 27A*1, 28A*6, 29A*1, 30A*1, 32A*1,
48. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
49. wealas 30A*1
50. linh0983 1A*1, 25A*1, 32A*1
51. Subbu K 25A*1, 26A*1, 30A*1
52. Karahana 3A*1, 4A*1, 6A*1
53. Patjr Ref. Line 8
54. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
55. Jack0k 1A*1, 20A*1
56. marcus1 - No longer required atm.
57. Photochum1 25A*1, 31A*1, 23A*1, 13*3
58. AirAir 20A*1, 21А*1, 23А*1, 25А*1, 26А*1, 32A*1, 33А*2
59. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
61. nounouchet 19A*1, 20A*1, 26A*4
62. wcwc 1*1, 2*1, 13*22, 19*1, 35A*1
63. cec 1A(Q3)*4, 9A*3, 12A*9, 20A*4, 22A*1, 23A*2, 25A*1, 26A*2, 32A*1, 33A*1, 34A*2, 35A*1, 13*12, 22*3
64. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
65. mnichols30030 25A*1, 27A*1, 33A*1, 34A*1
66. 18gb 1A*1, 3A*1, 17A*1
67. Morde 1A*1, 12A*1
68. bb870817 30A*1
69. judesu777 1A*3,3A*2,4A*3,7A*1,8A*3,9A*3,16A*2,22A*1,27*1
70. Pinnocchio StationPi * 2
71. Robin de Wolf 1A*1, 12A*2, 13A*4, 19A*1, 23A*2, 13*6, 17*6, 27*1, StationPi *1
72. Yatsushiro 35A*1
73. kenlaumm 1A*1, 5*1, 6*1, 10*1, 17A*2, 18A*1, 22A*1, 35A*2
74. Ghettocowboy 1A*1,20A*1,23A*2,35A*1
75. sernikus 31A*1, 32A*1 , 35A*2
76. druidaudio 11A*1, 13A*2, 23A*2, 35A*2
77. Xapri 13A*2, 22A*1, 12*1
78. TirNaOg (Q3) 25A*2
79. yannisdoc 7A*1, 33A*1, 34A*1, 28A*3, 26A*1, 25A*1, 35A*1, 31A*1, 27*1, 23A*2, 24A*1
80. ed linssen 35A*1
81. Big bird 35A*1, 7A*1, 27*1, 21A*1
82. kkla1016 1A*1 , 20A*1 , 22A*1 , 23A*2 , 35A*2 , 24Ax1 , 27x1
83. prohvesor 13A*4, 23A*2, 27A*1, 28A*4, 29A*1
84. Caad 30A
85. geoturbo 1A*1, 13A*6, 14A*1, 19A*1, 23A*2, 24A*1, 26*6, 27*1
86. adrian311 1A*1, 3A*1, 4A*1, 23A*2, 24A*1, 35A*1, 27*1
87. pz1 26A*1
88. titus2002 1A*2, 13A*8, 23A*2, 35A*2, 13*4
89. grarea 4a*1, 19a*1, 24a*1
90. STEDAV 12A*8 25A*1 26A*4 17*2
91. topicreader 25A*2, 26A*1, 29A*1, 35A*1
92. mahtew 20A*1, 25A*1, 30A*1, 32A*1, 33A*1
93. kvl 1A*1, 31A*1
94. Wirewiggler 25A*1,30A*1
95. Crom 1A*1,25A*4,26A*2, 30A*1,33A*3,34A*6,17*10
96. atom6422 13A*4, 24A*1, 25A*1, 26A*1, 27A*1, 28A*4, 29A*2, 30A*1, 31A*1, 33A*1, 34A*2, 35A*1, 3*1
97. samsie 1A*1,11A*3, 13*1, 17*8
98. Wirewiggler 3*1,35A*1
99. Alfista 1A*1, 3A*1, 20A*1, 22A*1, 27*1
100. themixmaster 28A*4 29A*1
101. Johnny Canuck 1A*1, 9A*1, 13A*2, 20A*1, 23A*2, 24A*1, 25A*1, 26A*1, 33A*1, 34A*1, 35A*1, 27*1
102. anry 24A*1, 25A*1, 33A*1, 35A*1, 17*1, 27*1
103. ke6fzi 1A*1, 9A*1, 12A*1, 13A*1, 20A*1, 23A*2, 24A*1, 25A*1, 26A*1, 33A*2, 34A*4, 35A*1; other items (19A*1, 31A*1, ...) & possible changes TBD
104. BrianGasberg 35A*1, 20A*1, 1A*1, 33A*1, 34A*2, 25A*1, 26A*1, 13A*4
105. tadek 9*4
106. 10y 1*1A , 4*13A, 1*30A , 1*31A, 1*22.
107. apotelyt 13A*4, 19A*2, 3*2
108. mvaldes 1A*1, 9A*1, 13A*4, 17A*1, 18A*1, 35A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 30A *1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
68. bb870817 30A*1
84. Caad 30A
87. pz1 26A*1
93. kvl 1A*1, 31A*1
105. tadek 9*4
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 30A *1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
68. bb870817 30A*1
84. Caad 30A
87. pz1 26A*1
93. kvl 1A*1, 31A*1
105. tadek 9*4
109. sgledhill 35A*1 StationPi please.
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 30A *1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
68. bb870817 30A*1
84. Caad 30A
87. pz1 26A*1
93. kvl 1A*1, 31A*1
105. tadek 9*4
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 30A *1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
68. bb870817 30A*1
84. Caad 30A
87. pz1 26A*1
93. kvl 1A*1, 31A*1
105. tadek 9*4
110.judesu777 1A*6,3A*2,4A*2,7A*2,8A*2,9A*6,18A*1,19A*1,20A*3,27*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 30A *1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
68. bb870817 30A*1
84. Caad 30A
87. pz1 26A*1
93. kvl 1A*1, 31A*1
105. tadek 9*4
Hi all, total newb here when it comes to Ian Canada products. I am currently using an RPi4, bone stock with stock PSU wall wart, to feed a very nice DAC (Denafrips Venus II) with USB. I would like to use the i2S input on my DAC but my current solution to do that - a Pi2AES - is very limited for DSD output via i2S. Since I use HQPlayer with a custom PC to output DSD256 for everything, Pi2AES can't help me there.
Just yesterday I ordered a FIFOQ3 module and HDMIPi module. My plan is to use those on top of my Pi4 but now having researched a bunch, I'm either confused, intimidated, overthinking it or all the above.
If anyone can help, I appreciate any guidance, on what I need further to make this work. Once I get it working, I intend to do any advisable upgrades (LifePO, supercap, better clocks, whatever makes sense).
I'm guessing to add to my current setup of Pi4, FIFOQ3, HDMIPi - I also need two LinearPis? One for the Pi (5V) and one for the FIFO board (3.3V)?
And if so, how are people getting power to the LinearPi boards themselves? I have a couple decent Meanwell SMPS options (5V/3A, 12V/3A) onhand, or should I use something different? And if I'm visualizing things correctly up to that point, are we just lopping off the 5mm connector and connecting the wires directly to the appropriate connector?
My apologies for posting the above in the Group Buy thread - thought I was elsewhere.
But just to come full circle; I ordered the LifePO4 kit because it satisfies all the different things I was looking to do. Excited to get it all in and together and try to get it all working without blowing everything up (ok I'm honestly not that bad at this stuff).
Ordered the batteries from CA, but it was kinda tough to find ones in stock. Anyway, thanks for the space and the patience, and happy listening
Hi toddrhodes,
Very nice DAC you have there, just got my Denafrips PONTUS recently and it worked really well with Ian's Board on I2S Output.
Should you consider to play Native DSD up to DSD512 you need to add: Bridge Pi + USB Amanero 384Combo plus Station Pi will be good.
But with these additional board, the audio signal is feed via USB Board and practically you have a Streamer (RPi) and a DDC (the rest of the Board) which you can still use to connect other USB Source (i.e notebook, PC, etc)
Hope it helps
@toddrhodes : My setup
PC install Roon
Stream to Dac Gustard X26
Pi4 + FifoQ3 + I2S(HDMI) ian
PCM max 768KHz
DSD max 22.4 MHz
Pi4 install SMPD ver 1.0.10 + Roonbirdge
symphonic-mpd
PC install Roon
PCM max 768KHz
DSD max 22.4 MHz
symphonic-mpd
Thank you so much for this!
I don't wish to clutter this thread, so if there is a more appropriate place, let me know.
I received my IC goods today:
HDMI Pi transmitter
Battery power supply (but no batteries yet, so it's not in use)
FIFOPi (latest)
For now, I just stuck HDMIPi on top of my Pi4 and was hoping I could just flash RoPieeeXL to it and at least get sound out of it. My DAC is already set up for the Gustard pinout, but neither my HQP NAA image nor any DAC "hat" I've tried - including the "Raspberry Pi DAC (i2S)" option in RoPieeeXL seems to work or even be recognized as an audio endpoint by Roon.
So SMPD seems like what I need to do next, but I see that I must become a member first so I've requested that in the thread you linked.
In the meantime, I will go back to my HQP NAA and toy around with the IC stuff as I can.
Edit - so apparently the issue I was having was something weird going on with Roon. I restarted everything in the chain and now I have i2S playback out of my DAC, from the IC board, using either Roon or HQPlayer.
So we're cooking with fire now. Now it's time to mess with the FIFO board.
HDMI Pi transmitter
FIFOPi (latest)
PC install Roon
PCM max 768KHz
DSD max 22.4 MHz
symphonic-mpd
Hil @linh0983,
Wow Nice Setup,
Do you mean that RPi 4 with Symphonic -mpd, you can play Native DSD512 from RPi4 via GPIO Pin to FIFOPi + HDMIPi and then to your DAC? so you wold not need USB Board/Bridge Pi?
How could I try symphonic-mpd image,
Best
Well I'm happy to say that I have it all working, but I think I need to solve the software side next because I'm only getting at most DSD64 output via i2S despite upgraded clocks in FIFOPi3 suitable for much higher rates.
I do have hope that Symphonic MPD could possibly serve as a solution here; just a question of whether I'll need other parts and/or will it work ok with Roon and HQPlayer.
Other than that - LifePO4 battery PSU, FIFO Q3, and HDMIPi seem to all work just fine together to their expected, "standard" settings as far as I understand them.
NO . I play Native DSD512 via USB Amanero / RecerverPi .Hil @linh0983,
Wow Nice Setup,
Best
Symphonic-mpd you can register here .
symphonic-mpd
ホーム | symphonic-mpd
symphonic-mpd
ホーム | symphonic-mpd
Dear linh0983 ,
Ahh got it, sorry for the joining MPD post
Video of My Best Sound Quality Audiophile DIY DAC I Built in 2020
The Best Sound Quality Audiophile DIY DAC I Built in 2020 - YouTube
Ian
Ian
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
