anachronous_one said:
OK, I greatly appreciate your input and advice. If I understand correctly, you recommend that I stop the color wheel with my finger and see if the lamp slows down the frequency of flashes until it completely stops. Is that right?
Your final sentence makes me think that I might be risking damage to the lamp and ballast if I attempt this test. Do I understand you correctly?
Yes, you are right, when the sync working, during the lower speed of wheel is clearly seen individual separate "flashing" lights of bulb. If not working, the light is not depend on the wheel speed. Im not sure if this procedure is dangerous for bulb/ballast, but the wheel is very tender subject.
Re: Re: tengo reemplazo para lampara uhp
To X_Online:tenes razon Lo que pasa es que una gran parte del costo es por hacerlas traer desde china hasta sudamerica, y por otra parte por aca una original cuesta mas de u$s500 aunque si vos estas en USA podes conseguirlas mas baratas
X_Online said:
Porque son tan caros?? es mucho dinero no??
Hi rorr!
do you have some pic of your SONY chip CXD3500R? I can try look for.
Hi anachronous_one !
you can send your old lamp assembly to me to rebuild
Hi X_Online !
what is your emailaddress?
Hi figure9!
your lamp is 200w SHP,
you need 200W BSM-DC
price is $80, shipping is $5.
I can take moneybookers only
Hi X_Online !
Hi figure9!
Hi rorr!
Hi X_Online !
Hi figure9!
Hi X_Online !
Hi figure9!
Hi everyone I am new to the board and this is my first post. I am glad I found this site lots of great posts. I have several projectors the ones i use the most are my 3M mp3650's and i just blew my last bulb i had for them. I am looking for a cheaper alternative than spending 900$ every time one goes. I am a electronics tech and just need the bulbs to fix these projectors. If anyone knows where to get just the bulb it would be a big help. Here are pics of the lamp.
the print on the side of the lamp itself says:
Toshiba
smdr350-ft
na19011-3181
I know its a 350w MH bulb i found just the bulb on a site a while back but cant find it again for the life of me. thanks in advance.
Toshiba
smdr350-ft
na19011-3181
Hi ElectricJ !
I think that is 8650 but not 3650, no 3650.
http://www.projectorcentral.com/3M-MP8650.htm
that is DC 350w MH bulb , price is $40, shipping is $5.
opps your right typos on my part. Can you email me at DjElectricJesus@yahoo.com with the info i need to get the lamps from you i need two of them. thanks.
ywh said:Hi rorr!
Hi X_Online !
Hi figure9!
HEY YWH!! its rrenav@nctv.com..thanks!
Hi ywh!
There is a tracking number of te bulbs you've sent?
I didn't receive it yet
Thanks!
Ri7
Thanks!
Ri7
ywh said:Hi Mclorkus! Hi Ri7
I have sent your bulbs last week end.
OK....so...i was wondering about having a replacement back up for future use on a bulb...(YWH, im sure you can help me with this one)
i have ordered a new SONY bravia VPL-AW15 projector, and just for back up...what bulb would i need? how much? thanks for all the help!!!
Sharp XR10X
I am looking for a replacement bulb for a Sharp XR10X Projector. I have seen some websites where the bulb can be replaced with a little work on removing the old one.
I purchased a second Sharp projector, same model number that also needs a new bulb, with the idea that I could just get another bulb.
I was told by one site that since I am in the US, the replacement bulb will not work from China.
Please help!
John
Please help!
John
Hi ywh!
We had a little problem...
I've just received ONE lamp today.
It's a 200W BSM-AC-L, witch is the right one!
But you don't send me the second one:
150W Metal Halide, JYS/AC
I have paided the both lamps to DIYPRO.US, but you sent me only one.
Can you send it to me?
Thanks in advance!
Ri7
Thanks in advance!
Ri7
ywh said:Hi X_Online !
I am waitiong fo you
Hi Ri7 !
there is a NO of post system:
rr490406175cn
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
