Goldmund Mimesis 3 Clone, World's Best Amplifier!!!!
Final Schematic Notes:
  • Goldmund Mimesis 3's Part List.txt
So many times this circuit has appeared and no one has complained till now about the "magic" 56V output WITHOUT any filtering capacitor... But talking about large pics is fine...:crazy:
Since Norbert will prototype the amp prior to selling boards this time I haven't much to complain about.
Without the caps on the amp pcb there's only rectified AC, okay.
What one could complain about is that nobody noticed he forgot to subtract the diode drop. ;) :) :)
It doesn't matter, it will make no difference. The sensitive input stage has it's own power supply which already addresses all of that. Small caps on the rectifier bridge are simply a waste of time I'm afraid.
But the big power supply caps might last longer , especially if the power supply is under heavy load. If you do quiet listening ..no , but for a "party amp" , the snubbers have a very beneficial effect (VERY oblivious on scope). :D
The secondary supply , even with it minor loading , would also benefit from cheap 10c .01uf/400v snubbers. This is common on the PS bridge of even the cheapest walmart surround receiver , is the goldmund not worthy of these additions ?? :confused:
OS
