Just curious... Are you saying that you prefer the FE103E over the FE126?
Yes, the 103 is a much better sounding speaker to me.
I've not heard the FE103e, i do like the FE127 over the FE126 (but i don't think i could live with either after having lived with modded drivers) and over the larger drivers.
dave
FWIW I've compared MP3, AAC, AAC+, Ogg, and CD, and they all sounded different in the top end to me. On top of this, I suffer (badly) from a constant case of severe tinnitus, and my hearing is also limited to about 16 KHz. That said, the differences between formats are easily audible.
I,m back for a moment via my 12" powerbook g4 fand 400w inverter
Yes, that is my understanding. I have read the story and will relay it here when I have more time but it explains how the shape of the enclosure relates to the speaker design.
That is considered to be an advantage - a point source.
Thats the tone I refered to earlier. Wonderful isn't it
Whole loaves and before that fire
My wife loves them and lovingly refers to them as the "E.T." speakers. Whenever I put a different set of speakers in rotation after a few days she always asks when am I putting back the "E.T." speakers.
TTFN
Are you talking an actual dream
The periscope small baffle presents its own problems.
I want to say that with piano music, these little drivers in these cheap boxes sound amazingly good! Lots of air and space, extremely "real" sounding, especially in the upper register. You can clearly hear the metallic sound of the strings with great detail.
And speaking of strings, listening to acoustic guitar is equally amazing. All of the detail is right there. It sounds like the guitar is really in the room several feet away from me!
so what was the best thing before sliced bread, and then before that?
to each his own - the sound should be the most important thing, and for those lucky enough to have a SO that could live with them- congrats - they look like more of a nightmare than a "dream" to me
TTFN
He yet lives... I don't envy you in the path of that little breeze.
Hmm. With that periscope, the Swans are effectively close to being an omni above the cabinet's gain BW, and at a somewhat lower frequency than most other boxes, so their behaviour is 'unusual.' Only works properly with certain drivers with a lowish mass-corner of course. Their polar response should / will reflect this (never measured one, but that's what will happen) -probably why I don't particularly like them myself, while some regard them as the best thing since the pre-sliced bread days. YMMV as always.
Re: Ping Charles
Hi Andrew!
Got your email. Thanks for those plans. Looks promising.
I have actually been looking at something like a smaller version of the curved Moose BVR double horn. It looks simple enough to build. I assume (hope) this design would work good with the FE103E's.
Andrewbee said:I sent something to your photography website as your email is turned off here.
Hi Andrew!
The plan I sent you is far away from a double horn unfortunately.
It is specific to the FE103e, there is a version for the FE108EZ which is 10mm deeper with a few changes in lengths internally.
Did you look at the Frugal Horn site? Scottmoose had done many double mouth speakers and you may find something pleasing there although I get the impression from his posting that he usually designs for the 4.5" and larger drivers e.g. FE127.
The plans you sent me or more of a TL, correct? If so, how do they differ from horns as far as driver loading, frequency coverage, output and overall sound (tone)?
I know the actual differences between TL's and horns, but not the differences in sound and driver loading.
Yes, I've been skipping through parts of the FH site, unfortunately usually late at night. So about 10 minutes into it, I start nodding off a bit. LOL I'll see how much of it I can get through today since I'm off.
Andrewbee said:Did you look at the Frugal Horn site?
At this point Suzy (single mouth) is the only one suited to FE103
dave
dave
I'm sorry, but do you have a link to this "Suzy" you're referring to?
So you are saying that there are no double mouth designs for the FE103 or none that can be modified for the FE103?
http://www.frugal-horn.com/spawn-plans.html
Scroll down. Suzy is a single mouth mBVR
A 1st pass at a double mouth version would mirror the vent/horn on top and decrease the vent depth by 1/2.
dave
dave
planet10 said:http://www.frugal-horn.com/spawn-plans.html
dave
I didn't see this page before on your site. Nice!
And sorry again, but I'm not too sure what that means about the whole double mouth bit you just said. Are you referring to the opening to the mouth that's already 0.50"? If so, then that means that that opening would be theoretically shut for a double mouth?
I was hoping on doing something in the lines of the Oliva Chang, IF it were possible with the FE103. That's not to say that I wouldn't upgrade to the FE126/127 later down the road.
chops said:And sorry again, but I'm not too sure what that means about the whole double mouth bit you just said. Are you referring to the opening to the mouth that's already 0.50"? If so, then that means that that opening would be theoretically shut for a double mouth?
There are 2 parts of the vent... the slot and the horn load/funnel. mirror the horn to the top of the cabinet and half the depth of the slot (ie if 0,5" with 1 vent, make it 0.25" with 2)
dave
dave
Okay, now I see. Thanks Dave.
So I could in fact mirror the Suzy? I assume all other dimensions would remain the same such as the horn load/funnel size and the rear chamber? Just that the driver should be mounted at mid-point in the chamber and one of those divider/reflector braces mounted on the back wall?
chops said:Just that the driver should be mounted at mid-point in the chamber and one of those divider/reflector braces mounted on the back wall?
yes. you might want to wait for Scott's comments before actually sawing wood.
dave
This is one of the boxes I've been meaning to revisit at some point. Unfortunately it's not going to be quite as simple as that (would that it were ) -the existing cab. basically uses the horn as an integral stand, so it's aspect ratio as is is already seriously OTT. A doubled version with the 103 would need to be done from scratch. I haven't done a new box for the FH site for a while, other than upgrading Olivia, so I'll rework the existing cab. & have a double-horn option too if it's wanted. Just don't expect them to have any bass.
Speaking generally now, the 103 (& the 108ESigma come to that) is a bit of a PITA to design for IMO. No -that's not right. It's just a case of priority. Trying to get any LF out of them while keeping excursion / distortion within vaguely reasonable limits is not at all easy, without resorting to a full-size horn or multiple drivers at any rate. I prefer to BW limit drivers this size when used solo, on the basis that 0 bass & decent mids + HF is better than a little bit of rubbish bass, the getting of which in the process wrecks the mids & HF.
dave
Great! It will be a short while before I start even buying the wood much less cutting it. I still have my vehicle install to do yet.
Scottmoose said:This is one of the boxes I've been meaning to revisit at some point. Unfortunately it's not going to be quite as simple as that (would that it were ) -the existing cab. basically uses the horn as an integral stand, so it's aspect ratio as is is already seriously OTT. A doubled version with the 103 would need to be done from scratch. I haven't done a new box for the FH site for a while, other than upgrading Olivia, so I'll rework the existing cab. & have a double-horn option too if it's wanted. Just don't expect them to have any bass.
Hello Scott.
I guess what I should be asking instead of saying "I want to have a double mouth horn" is... What is the point to having a double mouth horn over a single mouth horn? Does the double mouth increase efficiency, extend frequency range, etc, etc?
Also, I take it BSC still applies to horns as they do to normal sealed or ported designs.
As you can tell, I'm totally new to these kind of horns. I'm used to normal compression horns like the old Altec and Klipsch mid and high frequency horns and such.
chops said:Also, I take it BSC still applies to horns as they do to normal sealed or ported designs.
http://www.diyaudio.com/forums/showthread.php?postid=1654085#post1654085
Scottmoose said:Speaking generally now, the 103 (& the 108ESigma come to that) is a bit of a PITA to design for IMO. No -that's not right. It's just a case of priority. Trying to get any LF out of them while keeping excursion / distortion within vaguely reasonable limits is not at all easy, without resorting to a full-size horn or multiple drivers at any rate. I prefer to BW limit drivers this size when used solo, on the basis that 0 bass & decent mids + HF is better than a little bit of rubbish bass, the getting of which in the process wrecks the mids & HF.
I don't remember if I said this before or not, but I don't plan on these replacing my main speakers or anything. If anything, these are just a way for me to get my foot in the door (so to speak) in building and listening to full range single driver systems.
I never bought the FE103's with the intentions of using them in my home, but in the dashboard of my vehicle! But now that I have a taste for single drivers, I want to go a little further with what I already have and build actual enclosures for them, just something that will allow them to make some decent sound. Also, if I can, I would really like to NOT have to use any BSC or any passive networks as I feel that defeats the purpose of singe driver systems.
Once I build a pair of enclosures for the FE103's, then I'll be ready for something bigger and better with bigger, better drivers. I would like to eventually have a pair of single driver horns that at least have strong, usable output down to 30Hz or so, and of course get up to 20kHz or close to it.
planet10 said:
Thanks for that link Dave. I've also been doing a little research on Google about BSC.
- Full Range
- Fostex FE103E...
