From the PS in http://www.passdiy.com/pdf/zen-v5-hires.pdf
6 caps C4 -C9 @ 15,000uf or 30,000 for Turbo v2 for 1 ch.
AudioSan:
Thanks for the helps.
BTW, I read about your threads about dual mono above.
I am sourcing for chassis.
I just wonder if the PSU (Toroid transfo + 16 huge caps) is taken out to a short chassis and leaving all Stereo parts ( inputs & outputs ) in a 17" X 16" X 6" (high ) chassis with the mosfets mounted to the sinks with fins as 2 walls on 2 sides . With the big empty space in the center releases much of the demanding heat sink to 2 moderate sink of 16" X 6" X 1.5" (fin) ?
You know I am a newbie, just curious would it work for at least v2 with 32V rail (or v3 ) .
hello. if you have a well vented chassis. and +/-32V 4 pair of output fets.
say you bias it at 1.6A . 32x1.6x2=103W pr ch. (40WclassA in 8ohm)
then the 4U400mm(modushop) chassis will be perfect. or if you like to build chassis.
then heatsinksUSA's 10.08" profiles 6" are great. 2 pr side. they can do 130W+ pr side if the outputs are well spaced
Thanks. I figure to use Dual PSU in a ~ 4" high chassis to give 2 X 500W toroidal power house feeding the vented but no fan 4 pairs FET Amp F5 Turbo circuits.
The rectifying cost is mainly the 12 cap anyway and price of 800W toroid may be doubled that of 500W's. In contrast to 2 muscular 10" monoblock chassis building, this alternative approach save some steel for military tanks production
So we know we need about 2 six inch heatsinks 12 inches wide with 2 inch fins (HEATSINK USA).
if we used one common sink for cooling the diodes, how large would that be? Could you think of a configuration to have that third heatsink as the front or back panel of the enclosure?
I still like the idea of one enclosure for stereo, but im not sure how to make that work....
Thanks for answering my questions..
These would be nice heatsinks for the people in Europe, as suggested by Jacco, if they want to make their own case.
And not to expensive to (ex vat), Farnell sells these same heatsinks at about 3 times the price.....
SindoPower | Heatsink KL-285 (P3)/120 mm | A SEMIKRON-group company - online sales portal
SindoPower | Heatsink KL-285 (P3)/180 mm | A SEMIKRON-group company - online sales portal
- F5 Turbo Circuit Boards
