ESP P3A Layout
D
Deleted member 148505
Take one torroid, 2 caps, 4 diodes and you get a better measurement than with a 400 dollar power supply.... I cheated a bit by using an iPhones battery operated signal generator, but when I used the iPhone with the labsupply I got 50-500 Hz noise, with the simple torroid that's less.
THD+N is around 0.012% at 1.6 Watt (3.9 Vac over 9.4 Ohm)
Update;
And adding 2*10 mF caps damped the 100 Hz peak by over 5 dB and 50 Hz by 4 dB. We are making progress. 4 days the output looked like http://www.diyaudio.com/forums/solid-state/212342-esp-p3a-layout-4.html#post3040762
Nice:)
even-order harmonics are dominant
I did a THD+N test with the new layout. Performance is nearly identical. DC output is 2mV. There is some 50-100-150-200 Hz noise which I still want to suppress. For class AB, is adding more capacitance the only option?
http://www.diyaudio.com/forums/atta...5304d1338632396-esp-p3a-layout-added_caps.png
Is there a way of pushing the 50Hz peaks down? Better/different local decoupling? More PSU capacitance? Some sort of CRC topology PSU? Snubbered PSU (easiest to test, so I will use that today)
I use these transistors;
BC546
MJE15034
MJE15035
MJL4302
MJL4281
I added some capacitance and a 1R 100N PSU "Snubber" and the 100Hz dropped to -104 dB. I think the snubber is doing nothing, but the added capacitance helped a bit in the LF noise. Now I have 18mF (or 18000 uF) per rails for 1 channel.
Ow, and the LF measurement is caused by the amp/PSU. If I connect my signalgenerator/iPhone to the pc, there is no 50-100-150-200 Hz visible.
0 dBu is 0.77 Vrms
output amp -> 1:4 voltage divider -> PC
50 Hz -96 dBu therefore means; 0.000012277 Vrms on input of pc
0.000012277 Vrms * 4 = 0.049108 mV rms on amp output.
Connected to pc, AMP off;
50 Hz -113 dBu
100 Hz and up, masked by measurement noise.
Connected to pc, AMP on; Input open/floating;
50 Hz -75 dBu
100 Hz -102 dBu
150 Hz -102 dBu
200 Hz and up, -105dBu and lower
Connected to pc, AMP on; Input Shorted;
50 Hz -96 dBu
100 Hz -110 dBu
150 Hz -120 dBu
200 Hz and up, -113dBu and lower
Connected to pc, AMP on; Input connected to iPhone playing 1kHz sine;
50 Hz -96 dBu
100 Hz -100 dBu
150 Hz -115 dBu
200 Hz and up, -104 dBu and lower
In the previous post is a lot of info on LowFrequency energy content. However, I think you want to know the summed mVac on the output. It might seem bad due to the fact that I have a proper DMM.
Every amount of noise between 20Hz and 20kHz is measured and summed into 0.3 mVac. (shorted)
On the scope I cannot see a pattern, it is just flat/noisy.
Disabled Account
Joined 2006
SuperR, if you have a 2n5551c you should look at replacing the bc in the current source with this. For LTP BC546 is good, that is if its the BC546 C which has high beta. You can expect a handy couple of Extra Db in PSRR with just these 2 simple tweaks.
If you have D Self s book youll notice your output looks like an exact copy of his results when this problem area is not properly addressed.
Afters months of PCB-layouting, prototyping, ordering parts and some metalwork, I am proudly presenting the result of this project!
The only thing it still needs is a proper testrun and a mains-fuse. (My electronics store is not opened today)
What is on the pictures?
2 enclosures. One for the Minidsp and one for the amplifier
Minidsp is used for the sub-sat filter
The amplifier is a very compact device at which I am proud since there is quite a lot of electronics in it. (230mm wide, 280 mm deep, 80mm high)
350VA 2*25VAC torroid
Rectifier on side panel
Elco-bank of 4 pieces 10.000uF 63Vdc
Two mono PCB's
A loudspreaker protection kit
Neutrik RCA entrance and mains inlet
Ebay terminals
