Scottmoose said:around 12' wide or so would be my guess?
The posts holding the deck up are 12' apart so the baffle would be closer to 16' wide and 1.2 m tall IIRC.
dave
I decided to try damping the speaker frame (as suggested by Omega) so back down to Wal-Mart I went. Came home with several packages of "Feltac" polyester furniture protector strips (1"W x .5"H x 58"L).
A few hours and a whole bunch of trimming and cutting later, I ended up with what you see in the attached picture. Definitely made a difference in balancing out the sound more to my liking. The key part of the damping (IMHO) is shown as "A" in the picture. There's about a 3/8" metal groove between the speaker frame and spider that just can't be doing anything good for the sound. "B" and "C" are probably key as well. I wish I had an RTA!!!!
Here's a link to what the Horn Shoppe is doing with their latest and greatest Fostex:
Horn Shoppe 126E mods
On a side note, I have become very aware of box resonances when listening to "box" type speakers nows, including our floorstanders. I went over to a buddies last night to listed to his new 2-way mini-monitors with CSS WR125 drivers and was quite disturbed by the resonance (otherwise the speaker did some really nice things).
Visaton B200
Now if only those drivers were waterproof, Dave wouldn't have to worry about fitting them in the living room.
We first listened to them at my place many months earlier, and with a diagonal room placement, there wasn't enough space between the panels for me to scoot behind. (Dave - you still have those photo's?)
Tom: there's a quality to the bass response on an open baffle that's hard to describe, but the smile is easy to detect. Even the FR125/WR125's are amazing in this configuration - although sensitivity and Xmax limitations could be a problem.
Re: Visaton B200
chrisb said:We first listened to them at my place many months earlier, and with a diagonal room placement, there wasn't enough space between the panels for me to scoot behind. (Dave - you still have those photo's?)
Kensai said:And a gratuitous rear shot. Please notice my classy use of 3' lengths of freebie CAT5 remainders for speaker wire.
You should try a single pair out of the bundle -- better if you untwist them.
dave
Kensai said:This is a close up of the driver. You can almost make out the OfficeMax logo on that center binder clip at the top.
Are the cones aluminum or just painted... You'd get better horizonal disepersion and a wider sweet spot with more extended top if you rotated them 90 degrees.
Look like a good candidate for phase plugs
dave
I'm actually using one wire from each pair for + and the other wire from each pair for -. Sounds just the same as using the 10' lengths of standard 10ga speaker wire that I run in the living room.
They call the cone material "pearl mica P.P." so I'm not exactly sure what its made from. It feels somewhere between a treated paper and propylene.
I had thought that they might do better mounted vertically. I've actually had the fresh pieces foam core to make baffles for that set up for several months now. Just haven't come across the proper time/motivation quotient needed to get me to do the work yet.
I'm interested in trying to mod these with phase plugs. The whizzer is paper, and the dome in its center is about 3/4".
Kensai
Kensai
I'm wondering how low these B200 OB mounted go before you get to -3db? See, I'm interested in playing with these, but I don't have the cash for any more than (2) B200 drivers. I do have a HSU Research VTF-2 sub that crosses over up to about 125hz, but I'm not sure if I'm going to leave a big hole in the spectrum trying to do this.
Assuming the these speakers will mate with the above subwoofer, would this system be able to do double duty with home theater as well at moderate levels?
mrpopgun said:I'm wondering how low these B200 OB mounted go before you get to -3db? See, I'm interested in playing with these, but I don't have the cash for any more than (2) B200 drivers. I do have a HSU Research VTF-2 sub that crosses over up to about 125hz, but I'm not sure if I'm going to leave a big hole in the spectrum trying to do this.
Unless you have a tolerance for a very large baffle, the baffle size will limit the reach at the bottom, not the driver.
Relieved of doing bass these should be more than adequate to do HT....
dave
Hmmm, so then how do you determine the correct width of the baffle to tune the bass response so that is is easily crossed over to the sub? Adjusting the baffle width is a type of Baffle Step Correction (new concept to me) is it not?
How does width vs height of the baffle play out?
Wait, maybe I shouldn't be asking all these questions. I think I've just about talked myself into a pair of these
- Full Range
- DIY Open Baffle Full Range Speakers from Wal-Mart . . .
