That type of amp usually uses about a 2.5 to 3kva for 2-channel. Rated current draw on a similar commercial amp (Crest CA18) is 26 amps for 1/3 power typical max output. I'm pretty sure the trafo is only 2.5kva but at that size it could do 3 times that for half an hour before it thermals.
Try doing that with a switchmode and see what happens.
thank you, i suspected that much, reason i asked is that we are running a group buy in our local FB group and 120 boards have been spoken for...i think we can get a very good deal for that...
amp is completed
can you share us the performance of this amp?
that trafo is huge...look at how small the cd beside it...
regards
ees
our local group buy will use a traffo 2 inch center leg stacked to 5 inches and core will weigh in at 15kg...
4 x 50 volts secondaries bifilar wound...
2 mm board thickness, 2oz copper thru hole parts....
Nice boards sir Tony, can I join your GB for 2 please.
PS: pls add Timbukto Panopio to the local FB group, ty
yes of course....add me too as a friend....
i have a power traffo designed for this, it will use a 2inch CL stacked to 5 inches, i am going to use a mandrel made from acrylic to wind thecoils...
the secondaries will be 4 separate coils of 50 volts each, and will use 4 bridge rectifiers and 8 10000ufd/100vdc caps...
trapo details
/wire size
if using 2''x5'' any winding details pri/sec tunrsyes of course....add me too as a friend....
/wire size
- "DIY 1.5KW Bipolar Class-H"
