Not sure if this has been covered as yet, but...
...Daphile keeps crashing when indexing my music library from my Synology 413j. Daphile is attached to my 2820 via USB drive. I happens on many occasions. There are some 130,000 files and it gets to about 40,000 files and dies. Thoughts? Apologies for any oversights here as it is my first post
Daphile boots fine from usb stick but if I try a boot with stick and usb hard drive connected it doesnt, fine if I boot first then connect external usb drive. The proliant microserver I am using has no facility to choose which usb it boots from.
Any ideas.
thyristor44
Any ideas.
thyristor44
You need to check everything.. comp, DAC, amp, cables, grounding.. try with another USB cable..
Well as it turns out I have two amps. An Adcom GFA555 and an Adcom GFA555II the II being the newer of the amps but both 20+ years old. I had been listening to the 555II but have now switched to the GFA555 (oddly the older of the two at ~27 years). I have not heard the static or the pop since.
Question, pops always seemed to be in right channel. These amps are known for being noisy when shut down and this one in particular had a groan when the caps finished draining at the end but mainly in the right channel. Could failing signal path capacitors cause this sort of bleed through and the occasional static pop?
Try o install everything properly, absolutely all the information you have in the instructions which I link..Daphile boots fine from usb stick but if I try a boot with stick and usb hard drive connected it doesnt, fine if I boot first then connect external usb drive. The proliant microserver I am using has no facility to choose which usb it boots from.
Any ideas.
thyristor44
All this has no connection with Daphile..Well as it turns out I have two amps. An Adcom GFA555 and an Adcom GFA555II the II being the newer of the amps but both 20+ years old. I had been listening to the 555II but have now switched to the GFA555 (oddly the older of the two at ~27 years). I have not heard the static or the pop since.
The boot problem was the bios and I could set it to boot from any usb drive. Not used to up to date pcs.Try o install everything properly, absolutely all the information you have in the instructions which I link..
Thanks for help.
thyristor44
Hello.
is any body succeed to run a daphile inside a VirtualBox Virtual Machine on a Windows 8.1 hosts ?
the daphile VM is running, it recognize my usb DAC plug into the Windows Hosts and shared in the Virtualbox configuration, but no sound is going out the DAC;
What is strange is that when i change the audio file from a 44khz/16bit to a Flac 192khz, the DAC switch correctly but no sound.
Also , in the Windows host, the USB dac dissapear from Audio device as soon as i start the Daphile VM. Surely due to the fact that USB device are not part in windows ?
if you have any idea, i ll be happy
florent
florent
Ive tested a few wifi adapters with no luck. I´m looking for an pci (not mini pci) or an usb wifi adapter who supports bot access point and wireless connection to the wifi router
So, just to be clear, you want one that can both act as an access point and be a client?
Hello all,
thank you for your help
Tony
Ugh. I gave away the Daphile computer that worked with wireless, and have struggled since. Only occasional access to Daphile now, with an Edimax mini-usb wireless device, and I'm in a non-wired basement. Thinking a bridge might be my only solid choice for reliable connection of the Daphile computer to the network.
Thank you!! I had my Spotify credentials messed up in the Daphile advanced settings.Yes, but only the third party version seems to work. In Daphile menu you have to click advanced settings which will direct you to LMS. There you have to tick the third party Spotify option and fill in your existing account.
Working great, beautiful.
New update available with phase inversion and support for hard disks over 2T!
Can't seem to find the phase inversion. Is there a button or something to click, to do it on the fly? Wanted to give it a try today, listening to Elvis Costello.
Thanks in advance - Pat
- PC Based
- Daphile - Audiophile Music Server & Player OS
