Hi claudio52 and judo and all!
Please setup
JRiver Media Center follow this image, You can play DSD and all file , please do that! thanks
Please setup
Quanghao, I haven't received my trafo. Could you pls send me the shipping tracking number ? thank you.
do you get it?/
thanks
do you get it?/
thanks
not yet. can you send me the tracking number ?
Quanghao, the DAC is LOCK-ing to PCM 44k before foobar was started.
I do not know jriver AFAIK it is not free. I do not need a mediacenter I need a compact free enviroment to play SACD iso and hi-res and is remote controllable by an android device - as foobar. I do not like commercial software I would throw out windows if I can.
Andrea, what do you think your controller firmware can cooperate with an Xmos card or Amanero specific?
Do you see only 44KHz on display using Foobar2000 and Amanero usb module ?
To use Foobar2000 you can follows the guide on: H i F i D U I N O.
- download the last player
- SACD support (foo_input_sacd-0.6.1.zip to get foo_input_sacd.dll and - ASIOProxyInstall-0.6.0.zip)
- ASIO4ALL (ASIO4ALL 2.11 Beta1 to get foo_dsd_asio.dll)
- Kernel Streaming support necessary to play 384KHz tracks (foo_out_ks.dll)
- copy foo_input_sacd.dll, foo_dsd_asio.dll and foo_out_ks.dll in the directory C:\Program\foobar2000\components
If you select as output device the ASIO4ALL when you start to play any tracks an little icon will be insert in the Windows application Bar.
I had written in my previous posts when I was not - or I do not understand your question?
sorry, I have read now the post
Could you try to check the flat cable connection ?
Could you try to change the frequency to 192KHz on Windows Control Panel selecting the Amonero device ?
Could you test Kernel streaming on Foobar2000 ?
I could not edit my message as you so this part of the thread has no meaning now.
I know this(asio) and had tried without success. I may try this out again at night if you want. You have not answered to my questions - I do not think this is only foobar problem.
The last I was tried was KS as I wrote earlier and this is the best until now. I will try the others - cable,freq- at night.
To work in asio it is necessary to load another driver:
Index of /asio
ASIO4ALL installation can create problem with this pure ASIO driver.
To know if the DAC boards have problems test with KS on JRiver trial version and tell me if the sound is ok and the frequency change on LCD.
OK, thanks. AFAIR I installed this driver following Hifiduino, but I can not be sure the firmware conf was the same. For example after flashing the Amanero fw do I need to make the pcm,DSD channels swap with all fw version? My experience was it ruins everything. I will repeat the process for sure.
you can see the DSD in the LCD ??
YES this , but some contry can check :
PR104522478VN
with; B?u ?i?n Vi?t Nam - VNPost
thanks
No, I am not.you can see the DSD in the LCD ??
Can you please specify the error on your DAC. I will have a revised plan for each of you, so you have to listen to music DAC. Please, please help me
Quanghao
This is the current list:
1) Erlend Sæterdal
2) smoothquark
3) masterkey
4) misterwolf , Halook
5) MattMax
6) bertchai
please add your problem
Quanghao
1) Erlend Sæterdal
2) smoothquark
3) masterkey
5) MattMax
6) bertchai
This last message was sent to me or to everybody except me?
the sample
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
