Some problem with my DAC today, 30 sec after I switched on the DAC, beezing sound "dee" come out from the DAC, like the relay switch on and off quickly, but after I take out one tube(6H30pi), the relay work normal!
I've checked the voltage same as before.
Anyone can help me?
Anyone can help me?
Hi all
I tried a couple of times to buy the PCB from Quanghao's www,
but it keeps saying:
"There is no carrier available that will deliver to this address!"
My address is in Denmark ... but i checked, and it said the same to a lot of other bigger countries.
Am i the only one having trouble ordering?
Anyone can help me?
Please! check voltage by lm1084, before lm1084 and after about 1.8-2V.
Hi all
There are many wrong in the my web!
You can sent to me by e-mail: quanghao168@yahoo.com.vn
Hi all, one question,
As on the PCB on the IV stage, some values make on the PCB is not the same as the schematic, am I follow the mark or the schematic?
e.g. R29, R30, R45, R46 PCB marked 2K, but schematic stated 220K each.
Thank you.
The Iv stage!
if you use for DAC, the R29, R30, R45, R46 = 2K
If you use the sample On Pre: R29, R30, R45, R46 = 220K!
Hm, seems that Quanghao is not too ambitious with his projects in the moment...
Unfortunately it is worth to get one of these, as it is really a good performer, when built with the "right" parts...I would try it several times...
Hi Jogi !
I'm doing for the DAC-end PCB, please wait!
Quanghao
Quanghao,
You don't answer to emails.
You don't answer to pm also.
How do you expect me to buy your stuff?
Im sorry, i not get your E-mail!
Please sent me again!
orderd my PCB ...
so i'm sourcing parts while i am waiting. What is the spacing between the holes for the resistors and capacitors?
(Mouser doesnt have 47 Ohm, og 220 ohm in CCF50, so i need other parts there anyway).
and BTW ... what would be candidates the best resistors for digital circuits? - the same as analog audio (shinkoh, Z102, Caddock etc.)?
Could easily fit 1/2w resistors like PRP. If you order from Mouser, try Koa Speer 1/4 or 1/2w military series which are rated 500v and 700v respectively. I use the 1/2w ones in my T2 build. For caps, as long as you use the correct values, whatever will fit. Sanyo oscon SP are best for positions around the AD1865. Other places, Panasonic FC/FM or Elna would be perfect.
Best resistors? Definitely the TX2575s. I have 10 of them in my DAC END and all sound sublime. I really don't dig the tantalum ones. Caddock is another great option, make sure you use their top-of-the-line series, TF-USF.
The relay sounds as a sidewinder does. My case is the same.Some problem with my DAC today, 30 sec after I switched on the DAC, beezing sound "dee" come out from the DAC, like the relay switch on and off quickly, but after I take out one tube(6H30pi), the relay work normal!
Anyone can help me?
because the relay shares the voltage with the filament so the voltage at relay droped under 5v (transformer underfeed it) caused the ralay hesitate to hit. Pls use a 9v/3A one for the instead.
Quanghao claimed that it's due to the voltage drop on LM1084 was not up to 1.8-2v
Hi Quanghao,
I have the same problem as crazyfrog, I sent you two e-mails to order you pcb of the DAC End + Tube stage but I had no answer of your part.
I am really interested in this DAC and I would really like to realize him it.
Fred
My e-mail: quanghao168@yahoo.com.vn
thanks
- More Vendors...
- Quanghao Audio Design
- DAC-ASH (dac-end 2 up date)
