Nuuk said:
I was listening to some female vocals today and it was not great.
The one with the directly digital amp (probably TaCT) I talked about (ralf) says he uses a parametric EQ to let female voices sound less nervous. I had this problem before I mounted my side walls. Maybe you both have a hole in the middle with your plain baffle/subwoofer concepts.
Nuuk said:I hope to get my hands on a T-Amp soon, and one of the 41Hz class D amps too. How do you apply the 100mA current limit?
I have never thought of changing volume by varying the voltage rails! I presume that you need highish voltage rails to start off with.
I'm not sure about the low cost version of the TACT chip. Some more research to do!
I simply used the current limit of my lab power supply.
I looked at the schematic of the T-Amp and the only problem I can find is that the gate voltages would have to change, too, to get proper gate-emitter-voltages.
Good guess! I have just come back to the PC after adding an extra (temporary) 7 cm to the width of the baffles and the female voices are much better.
It seems that the Ciares don't fill out the bottom end to meet the subs as well as the 201's (on the same size baffle). I would have measured it by now but I am still waiting to replace a monitor so I can use my second PC for that purpose!
Anyway - PROGRESS!
Nuuk said:and then re-built/modified by one of the best speaker craftsmen in this country!
do tell...
dave
do tell...
No secret Dave! His name is Dave Smith.
From Decibel Dungeon
Dave Smith of DK Loudspeakers is located in Essex and has a long history of working with loudspeakers. There's not much that Dave won't try and repair if he has the materials to do so. He has even repaired a unit from a 1920's radio! If you have a drive unit that needs repair, the best thing to do is give him a ring on 01708 447 344. Dave openly admits to having been completely left behind by computers so there's no email or web site but you can fax him on the same number.
Thanx, I may well have some drivers worth shipping to England to see if they can be repaired.
Does he have any tricks for "stiff surround syndrome"
Unfortunately is haven't spent as much time at DD as i would like... i find that, even with a CSS compliant browser, the dark text on the dark background is still VERY hard to read, so if i want to read something,, i have to print it out with ignore colors turned on....
dave
Nuuk said:From Decibel Dungeon
dave
It's good to see others tring the Ciare Ch250. I also have had Goodmans on OBs but mine were 301s. I did prefer the Ciares after a good break in and the extra magnet glued on. I also lifted the bass off the driver and added a zobel. Doing this to Lowther PM7a killed the music, but it was a definate improvement to the Ciares. I do not understand why this is.
The thing with these drivers is the cost to benifit ratio. These are cheap, and better than a hell of a lot of vintage drivers that I have tried on OBs over the years.
I will go back to the Lowthers,but this time on OB not horns.
I think that the amp driving the speaker is the most important thing with these types of driver. I had a Gainclone amp lent to me by a dealer. This amp made the speakers lifeless and hard sounding, but also thined out the sound.Maybe the output impeadence is too low on these amps.
Cheers.
Cheers.
Nuuk said:Thanks for the reminder. I'm using an inverted LM3886 with snubberized PSU but I'm using 37 volts rails. I'll swap the PSU for the 27 volts one and see what happens.
Nuuk said:Yes, things are slightly better with the lower voltage supply! I had forgotten that the Ciares are 4 ohm!
That's too much voltage for the LM3886 to be used with 4 ohm speakers
Of course you know that, you just forgot.
I use +/- 30V, which is fine for 4 or 8 ohm speakers.
You should have good results with +/- 27V.
el`Ol said:Seems to be a very interesting chip. Can I choose any rail voltage? Can I use it fully driven and do the volume control by controling the rail voltage?
No, you can't do that.
That's digital amp territory...
el`Ol said:Sorry, I thought it is Class D. But the only Class D amps I know that do the volume control this way are the very high priced TaCT amps. Do you know a cheaper amp that does volume control this way?
Yes.
Some (AV) Panasonic amps do that.
digi amp
..Panasonic Sa-XR 70
a friend aof mine has the big TACT and the smaller newer Tact for Euro 3000 plus room cororrection.
They do not sound better than the Panasonic at all !!!
We have direct komparison.
Ralf
Because of the low price of Panasonic its not worth to build a t-amp.
Ralf
The only fly in the ointment Dave is that because he is so good, and a one-man operation, and is a perfectionist, there is a (long) waiting list. My 201's were away for nearly a year!
Is that like an antidote to Viagra? Serouisly, it may be worth giving him a call and having a chat.
Please take another look!
Peter, are you referring to a Zobel across the speaker as opposed to the one on the output of the amplifier? If so, what exactly did you use?
I would say the sound is a little 'hard' not as 'full' as with the 201's but it's certainly not 'lifeless'. The term Gainclone covers quite a wide variation in specification!
Do any of the 41Hz.com amps fit the bill?
I found some neo donuts at allelectronics.com
2.83" in dia., .35" thick w/ a 1" inner hole.
http://www.allelectronics.com/cgi-bin/category.cgi?category=370&item=MAG-92&type=store
here's a physically bigger , but ceramic one:
http://www.allelectronics.com/cgi-bin/category.cgi?category=370&item=MAG-87&type=store
In the USA their shipping charge is $6 per order
Not much good for home cinema in a small room!
Variac said:I found some neo donuts at allelectronics.com
My mind is churning now.... i'll need to get a longer cable to measure T/S
dave
No excuses now... thanx muchly
I aim to please!
BTW Dave - do you suffer from some sort of colour-blindness? I only ever had a couple of people complain about the previous colur scheme.
- Full Range
- Ciare 250
