hifi said:
I prefer the more classy look of wood with Peter's current proposal.
Peter, good answer, I like that.. where do I sign?
Chris
hifi said:
I think that that design is rather ugly, and would much rather prefer having everything in one chassis, even if it costs a bit more money.
Brian
Peter Daniel said:Worth mentioning is also the way I'm putting the shaft through front panle. I also found a simple solution to that, and I'm using here a plastic washer available from Home Depot. For more "snug" fit two washers can be used.
Hehe - you read my mind
'cause I also had some ideas how to get the shaft through front panel - I had in mind to use some kind of a plastic "T" part (similar to the ones that are used as an insulation washer for transistor mounting - only bigger) ... So I see we have similar ideas
Brian
Yes, and the money for THE forum!
hifi said:
Like some people allready said - this case is a bit ugly for my taste ...
Wiki page should come up any time now.
To save on price even more, I could also offer two versions of the chassis. One prefessionaly finished (brushed and anodized) and the other, like you see in a picture, unfinished extrusions. Basically, only 3 panels have to be really treated, front, top and bottom and if you can live with rough finish (or if you just paint it) you will save in this way. The wood panels will be precut, but not treated in any way. It's up to the owner to choose the finish. Only maple will be offered
Knobs are not included either, as it's very personal choice. Shaft extenders will be included.
Over the weekend everybody can post their interest on Wiki page and I will get the quote early next week.
Here's the Wiki page:
http://www.diyaudio.com/wiki/index.php?page=NI+GC+Chassis+Group+Order
Please specify finished and unfinished chassis.
hifi said:The heatsinks where cool but sure it looks kinda like an owl..
just thought you guys should be aware of its existance anyway
/ Mikael
Yeah, thanks for the link, and it also put me into prespective of how much good things are cost/priced in the real world too.
Chris
Btw - what's the cost of bare Aluminium in your countries??
For plates of max 8mm thickness - the price is cca 18$/dm3 - so you calculate the volume of the panels and multiply and you get the price ...
If they are thicker - then it's a little bit more expensive ...
And the panles are protected on one side with PVC "sticker" - so you don't scratch it when you drill holes, etc ...
I shall build a chassis for my GC - sized cca 250 x 250 x 110 mm - all panels except the back and bottom will be 8mm thick; and there will also be another panel inside that will divide PSU (2 EI high quality slovenian custom build transformers, 160VA 2x18V each - they've cost me around 50Euro/63$ both) compartment from the rest of the amp - and the material will cost me around 35$;
And the "eloksation" (I think that's same as anodizing?) of the Al plates will be cca additional 10$ ... So for a little less then 50$ I will have my amp case done OK, ofcourse - probably I will spend so many hours that if I would be paid for them - I would get around 100$ - but hey - I'm a student - and I have some free time that I like to spend for my hobbies
I mean - was is my point - it's quite hard to get e.g. Black Gates or atepped attenuators or Cardas binding posts, etc etc in Slovenia - but - on the other hand I think that the transformers and housings are quite cheaper than in your countries ...
Peter Daniel said:Brian had similar layout and he didn't noticed any intereference. But I will build this amp over the weekend to know for sure.
I have the transformer in my chassis, and I get absolute no interference of ground noise from the speaker. I was amazed, as I get a slight hum from my Leach amp.
Here is a picture taken by Enigma from here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=28048
which is what sparked this who group order. I built this chassis about a year ago for an apox-gainclone unit, but never finished it, until my friend Eric (Enigma) wanted to borrow it for his gainclone until he finished his chassis.
Here is the link to the Chassis Wiki:
I added a table for the type of chassis.
Brian
Stabist said:Btw - what's the cost of bare Aluminium in your countries??
I shall build a chassis for my GC - cca 250 x 250 x 110 mm big - all panels except the back and bottom will be 8mm thick; and there will also be another panel inside that will divide PSU (2 EI high quality slovenian custom build transformers, 160VA 2x18V each - that costet me around 50Euro/63$ both) compartment from the rest of the amp - and the material will cost me around 35$;
I can use a few of my cookies tin boxes that I have collected over the years for no costs too
Yes we can do one ourself of course. But I like the idea of a good quality kit and money for the forum for those who were thinking of putting money up for the forum anyway..we just have to live with our means I guess..
I think I was a little misunderstood - I didn't want to say that Peter has too high price!!!! - I just happen to notice reading this forum for cca 1,5 yrs - that the chassis costs and the transformer costs are much higher than here where I live - but on the other hand - for a student without credit card (me) it's almost impossible to get better audio grade parts as BG caps, Cardas bindingposts, etc etc - 'cause there is NO company here that would sell them - the only choice that is left is Net ... But again - there are few other problems connected with taxes, ... when ordered from non EU countries ... So
chris ma said:Stabist,
Sorry that I took it the wrong way
Chris
Hehe - no hard feelings
Btw - what's that quite a lot of you mention - about donating some $$ for this forum through Wiki?? Sorry for me not beeing updated with such kind of stuff ...
Peter,
I think the 2 options you mentioned make a lot of sense.
I was thinking that the cheaper one should not have wood either as someone mentioned, BUT if it is unfinished wood, I suspect it doesn't add much at all to the cost, so why not include it!
Of course price is the determiner: if it turns out that the fine finish one only costs $15 more, then who's gonna get the cheap one?
I assume you will still get the stereo volume control- BUT why not have it as a separate product - it won't make your shipping much more complicated, some might prefer not to get it because they have something on hand, others might want dual mono , etc. I'm the opposite: I probably can't afford your chassis at this time, but I sure need the stepped volume control!!!
thanks,
Mark
thanks,
Mark
- Chip Amps
- Chassis for a group order of non-inverted GC kit?
