I'd pay more attention to output transistor matching rather than using 6 band resistors
I'll also pay attention to transistors. Thank you
D1 and D2 are small signal silicon diodes, not zener diodes.
1s954 small signal diode 50v
Rev 5:0
Please upload schematic diagram of REV 5
The 1n4148 is such a cheap part, 100 for a few bucks, no hassle, I'd stick with the intended, otherwise compare spec sheets, by eye they look similar apart from voltage
thank you I have 1s955 75 v 200ma small signal diodes I use them
4B v5.0 just add two 100n cap
Thank you..
at the entrance 2 pcs 1n4148 unused in rev 5
- Bryston 4B SST clone
