Rodeodave,
Yes, that cavity is to fill with sand bags, i'm doing it right now!
I used a foam on the front wall as you can see, but in the botton (in my case is the top) I used a long fiber damping, like a cotton. You can't see it on the pictures.
I used the #29 pieces, with spaces between them. You can see it here.
The sound, listening in the way that you see on my last picture, with no sand bags, I found that the highs are very clear and detailed, and so as the midrange! I notice that they get better during the first auditions! The bass is weak, but In this condition I cannot demmand much more from the bass.
I'm very satisfied by until now! If i'm linking the sound with this Pioneer receiver and old LD player, I can't wait to hear this with a single ended tube amplifier and a Hi-end CD player or Vinil!
Planet10,
That cavity is on the bottom, not the top. The enclosure will be on a shelf, so it needs to be upside down! The box is 20cm higher from the original project, so the speaker will be in my ears level. The cavity will be filled with sang bags.
I'll post more pictures later.
Thanks for all the help guys!!! Very much!
Guilherme
Planet10,
Guilherme
Here is the picture of the enclosure on the shelf:
Guijs said:That cavity is on the bottom, not the top. The enclosure will be on a shelf, so it needs to be upside down! The box is 20cm higher from the original project, so the speaker will be in my ears level. The cavity will be filled with sang bags.
I saw the pic below before your response... it was all i needed to understand completely.
dave
Guijs said:As you can see how my speakers will be disposed in the room, do you think that i'm doing right going with the original Fostex plan, or it will be better going with the Bushorns mkII?
I can't comment on the horns you built, but my experince with the one Fostex horn i did build has not been outstanding (i haven't given up on it).
The B-Horn II is a known entity to me. I know it works well.
As to bass. The 108es needs a couple hundred hours on it before its bass comes to the fore (and it will never produce lots of bass in the B-Horn or the Fostex. When fresh you should expect very little bass. The lack of bass is what is promting Chris & i to come up with a new design that is closer to a consistent horn than the TL/Horn hybrids that the Fostex & Buschorn represent -- the Qt on the FE108ES is quite low.
dave
PS: a current amp would help in the bass, but you might soon run into excursion issues. What amp are you using?
Dave,
I changed the cheap optical cable I was using by a cheap Analogic RCA cable and the bass got better. You're right, I need to wait for the speaker to burn in before worry about BASS.
I'll wait for the speaker break in and then i'll test some tube amplifiers. If I still feel that I need more bass, i'll try the Buschorn mk2.
PS: "Current amp" do you mean a tube amplifier? At the moment i'm using just a Pioneer RECEIVER with an old LD player. I'll use these equipments during the break in period, and then start to try some tube amplifiers.
Guijs said:Pioneer RECEIVER
That is not going to do it....
A no-feedback SET amp tends toward being a current amp (Chris' EL84 parafeed (in triode or RH mode was beauty with the FE108ES in B-Horns), a SEP or PP Pentode amp with no feedback is decidedly a current amp.
dave
Rodeodave said:I can see that you are using the original parts (#29) to fill the compression-chamber. Are there spaces between them so that they fit the 170mm? I'm thinking about using two 170mm wide pieces instead. But I'm not sure yet...
You can use just two 170mm wide pieces. I did it also like that. The only reason the used the 6 pieces instead that they didn't fit in the original cutting plan.
Hope to see some pictures soon.
Here are some pictures of the speaker I build.
Alexander
Guijs said:Do you guys thing that the B-horn will work upside down?
You'll miss the floor loading it was designed to use....
dave
Guijs said:a pair of tube 30w p/ch monoblocks with EL34 in pentode... simply loved it!
And when you get a hankering for more... those will make a REALLY good 8-10W Class A differential amp (EL34 in triode or 2A3s)
dave
Guijs said:What subwoofer to use with the FE108ez?
Wich kind of enclosure? Sealed, ported, TL?
Sealed, TL, or aperiodic. You want something that is quite extended at the top -- a woofer rather than a subwoofer.
dave
- Full Range
- Back Loaded Horn with FOSTEX, some questions...
