32V rail Aleph J
I would like to try building an Aleph J with a small turbo. Having read the F5 turbo manual, I am thinking of using an "as close to standard as useful" Aleph J circuit but powering it with 32V rails.
For the power supply (1 PSU for both channels) I plan on using a 625VA, 2 x 24V AC transformer with a CRC PSU. Each rail would consist of:
I assume the JFets are OK (as in the 32V F5) if I use a heatsink. Luckily I have some Xen/EUVL dual TO-92 sinks. I knew they would come in handy!
What else would I need to change to get it runing properly?
Edit: I forgot to add that I plan to use a 4U 400mm Modushop case (0.20W/C per channel).
- C: 2 x 15000uF/63V Panasonic T-HA
- R: 4 x 0.47R/3W
- C: 2 x 15000uF Panasonic T-HA
+ 4 x 1000uF/35V Silmic
+ 10uF/160V MKP
cascoding input jfets is recipe for better sleep
Ah, but then I would not be able to use the Peter Daniel boards.
How high can I go before I need to cascode? 2 x 22V AC be OK?
you can cut few traces and drill few holes
that's just 2 BC transstrs and 3 resstrs , plus one cap
Thanks Zen Mod, but I am afraid it would be too difficult for me at this stage. I am a newbie. So far, I have only assembled an O2 (headphone amp) and a DAC (from Spencer/fetaudio). Both were complete kits, with instructions
Would I get away with a 2 x 22V AC transformer (29-30V rails) and keeping everyhing else standard?
yup
what do you mean by Aleph J turbo ?
An Alpeh J with a bit more power. Read the Firstwatt F5 turbo manual on the Firstwatt site. Or check out the F5 turbo discussions on the forum.
For the Z-th time : the numbers Modushop mentions are for Class AB amps !
At over 130W dissipation per channel, the heatsink temperature will be at least 60C.
You'll not get more powah merely by 32V rails, requires more action : either higher bias or larger turbo boost.
Be careful, as i am not 100% sure that the ACS will function properly with the diodes in place.
I do not intend to do that. Just increase rail voltage.
Thanks Jacco, but I don't understand why the Modushop enclosures would not work. I have a set of Aleph 2's (monoblocks) running in identical enclosures. A friend of mine made them for me 6 years ago, and they have been running fine ever since. If I remember correctly the Aleph 2 is rated at 300W dissipation (per channel), hence my choice for this enclosure.
Nelson explains that on the F5, upping the rails 32V will give about 50W.You'll not get more powah merely by 32V rails, requires more action : either higher bias or larger turbo boost.
Why would this not work on the Aleph J? I do not expect a big boost, but a bit more would be niceIncreasing the power supply voltage is the obvious way to get more power out
of an F5. You can simply raise the supply rails to +/-32 Volts and get 50
watts into 8 ohms right away without other modification. 24 V AC secondaries
on the power transformer will do it.
It is about more than rails. I believe the AJ in standard setting is biased higher than F5. Pick your poison, just watch the temperatures. You could double up on the FE Jfets and increase number of output fets like i did in my monoblock build.
- Aleph J Schematic
