Aleph J illustrated build guide
bias good, DC offset bad!
Hello friends,
I recently had to open up my Aleph J and in revisiting it after a couple years I found the DC offset had risen...a lot! I tried to re-bias and realign the DC offset but cannot get it back down to what I consider reasonable. Right now the left channel is at 47mVDC and the right is at 95mVDC.
Any suggestions? :confused:
Hi everyone
I'm a long time member and haven't been on diyaudio for years. I decided to replace my Aleph 30 that I built 7 years ago with an Aleph J.
I built a power supply, populated the boards, and tested one channel. After some adjustment, it seems to work fine.
Now, I power on the other channel. I measure R18 and I get 0.35V. I measure R19 and I get 0.9V. After a few seconds Q8 was smoking.
Why do you think this happened?
I made sure Q7 and Q8 were matched, Q5 and Q6 were matched too.
R27 was set to 68K, R8 was set to 1K.
