The gain of the amplifier will be down if the -N is not grounded using the rca inputs.
What he said
The resistor with the chipped coating is fine. You don't need to patch it either ... They are pretty much indestructible unless they crack in half.
Thanks, that's reassuring but Soundhappy's offer is really great, so I sent a PM to him to replace the resistors.
Hi Folkdeath95
You got PM
Greetings
Hi Folkdeath95
You got PM
Greetings
Soundhappy, very kind of you to help out a fellow diyer.
Dennis
I have a question about the ground on the Aleph board, on the pictures in the building guide i see a bridge connection between the gnd and the -in, am i seeing this correct?
Correct.
No particular reason -- that wire was near at hand when I soldered it.this is a very thin wiring, why is this?
Slowly but surely, as is my style, I make progress.
Looking good! Carry on!!
Dennis
Yes, I appreciate it a lot. I replaced the cracked resistors with the two new Soundhappy sent me.
Boards are now ready:
Mikael
Hey guys, it looks like the white cable that runs from the psu to the boards is cut into halve and then soldered to gnd1 and gnd3, Am i seeing this correct or is this just my imagination?
Which pic are you talking about?
Hi Folkdeath95
Congratulations great diy work !
I like your photo with amp on old stone traditional wall in Bretagne.
In that photo it does look that may be true.
But no, the white wire is just attached from PSU gnd to the amplifier board.
And even if the wire were split and attached to both of those pads, electrically it would make no difference at all.
What do you think about good low noise separate power supply for jfet's (e.g. TPS7A4700) ?
It's worth it ?
impossible
input Jfets and lower mosfet must stay on same voltage potential
- Aleph J illustrated build guide
