..... but I can't figure out R17 ........ can't find a reference to them in the manual.
in the tube list, at the very end of manual
ups, mine is the mono solo board, obviously with different numbers
in my kit R17 is not related to heaters, but adjust the PSRR 'system'
but I thought at least the numbers in the large tube list would be the same through all versions
is Broskie not too smart, or being exactly that
at least its definately very confusing
I just dont understand how you can ad like 50V from B+ to CT of the 6.3V(or 12.6) heater trafo, and still have 6.3V
Because the 6.3 volts is floating.
You can't do it when the heater voltage is referenced to earth.
Also, make sure the voltage and value uF are correct...even if the bag is labeled correctly I have had a couple where JB must have been tired or had a few, luckily the last one I did not catch was just one of the heater caps, it was a 47uF 450V instead of the 10,000uF one. Since they were both the same size and type (the black Nichicons) I missed it as well and didnt catch it until the amp was complete and couldnt figure out why my heater voltage was all messed up.
Yes, one of the leads has a cross-hatch pattern stamped on it, which I could assume to be positive- but I didn't want to take chances with these in particular.
NO....that is the negative....I just checked one I had from a JB kit.
- Tubes / Valves
- Aikido 9 pin All in One Build
