6V6 line preamp
hope i got it this time ...
tried ss rectifier, IN4007 and a 100Ohm in series before c1, measured 440VDC with no load ...
tested SSHV2 ...
didnt have 8.5Κ dummy load, closest was 7.6K (series 4.7/2.2/0.68) ...
R4 was set to give stable 40mA, but with R11 fully turned I measured 291V across dummy load ...
will try later with 44mA to see if I get 340V across dummy (that is if I done the math correctly :rolleyes:) ...
the whole thing lasted about 5 minutes ... 2540 heatsink run quite hot, 840 heatsink was cold ...
SS vs Tube rectifier
DimZ, I am following your recent posts. Are you planning to do a listening test: IN4007 vs 274B? I would love to hear about that.
I have all the parts for my build but am on the fence about the rectifier - only because I was making an order from Antek and got a toroid for the Salas project too - but w/o a 5V winding.
Note that I am currently using my version of the "International Loesch" preamp which uses a soild state bridge and still sounds fabulous.
Mike
