I will post schematics soon,Hi Apex !
can you share with me your Vu meter schematic and pcb layout? iam intrested to build and add to my quasi Nmos 350 amp.
thanks
vijay
Thank you for share high power pa amplifier.You can't save cost diying pa amp, only you can easy fix it if you diy with avaible parts. I share H1200 soon, three amps work almost one year, without problems.
I waiting for you share H1200.
Best regards.
....... I share H1200 soon, three amps work almost one year, without problems.
Aha.....I'll waiting this PA H1200 coming soon...
Hvala puno...
I think H2500 is more interesting for you, or D3500Aha.....I'll waiting this PA H1200 coming soon...
Hvala puno...
Hi apexauioI think H2500 is more interesting for you, or D3500
H2500 how watts per channel ?
Hi Apex !
thanks
vijay
Hi vijay_meyou & apexaudio
I share power LED audio power meter 10 scale for velleman kit ( R13 select Low & High power mode 0.15 W to 2000 W ) for application disply for PA amplifier.
Best regards.
Best regards.
Hi Teslar!
Thankyou for sharing
Really i was expecting some stereo 2 Channel VU metter with PCB layout.
He...he...Are you sure will sharing this PA?
Thanks alot..
Pozdrav...
Give me some time, I am new on this forum, what will be for a year?He...he...Are you sure will sharing this PA?
Thanks alot..
Pozdrav...
Hi Teslar!
Schematics application for velleman kit.
Best regards.
For this power in modern H-class amplifier one step fet per rail is enough.Lem audio 130 watts power heavy duty design AB+H bipolar output and bipolar drive.
Best regards.
That amp is class G, it's not a switched rail like an H class ampLem audio 130 watts power heavy duty design AB+H bipolar output and bipolar drive.
Best regards.
Looks interesting though, fairly simple implementation.
Pioneer A-509R use IRF540/IRF9540 and there is OP amp in input stage. Have anyone expirience with this amplifier?
Surprised me that you have interest with amplifiers of "that" level. Cheap opamp, cheap drivers and most importantly cheap output devices. It only interests businessmen for creating commercial amps. But I will tell you that imho you don't understand who these DIYers are (in this forum) and may be the audio market. They aren't after cheap stuff like that (yes, some of them are after good brand name such as sony/pioneer, whatever the sound quality).
What I don't like from that hexfet simple topology is it surely require output relay protection, but the most important thing is I don't believe they can sound good even in class-AB. With this simple approach, the best sounding topology I have found is your darlington you posted previously, but with discrete darlington. May be a little bit expensive but definitely better than those fets.
Add/Edit: Oh, for high power one (such as PA) the darlington topology is I think cheaper (e.g. triple darlington), and a lot more stable.
I have interest for this amps only for hoby and fun, I agree that topology in my 100W Ultimate Fidelity Amp is superior in any way compareing with this Sony and Pioneer. Pioneer A70 from 80' is some different thing...Surprised me that you have interest with amplifiers of "that" level. Cheap opamp, cheap drivers and most importantly cheap output devices. It only interests businessmen for creating commercial amps. But I will tell you that imho you don't understand who these DIYers are (in this forum) and may be the audio market. They aren't after cheap stuff like that (yes, some of them are after good brand name such as sony/pioneer, whatever the sound quality).
Amplifier have signal GND, and power GND separate route on pcb, can be connected with 10R for test.Hi Apex,
Are you sure your grounding circuit is OK?
I had one - it sounded fantastic! - Beefed the power supply up with more electrolytic capacitors - amazingly fantastic sound.
My ex coworkers still uses it, and he loves it so much.
- 50W mosfet amplifier IRF540/IRF9540
